Old 09-20-2010, 08:13 PM
hurricane hurricane is offline
hurricane is on a distinguished road
Default need help buying parts
hi guys .. i have an h2 with coil springs, its time to re-install the airbags and compressor... anyone recommend a good website to buy airbags and compressor?
2003 Pewter H2
- BFG's, Electric fans, Coil spring, Magnaflow Muffler, Xenon HID.
Old 09-20-2010, 08:43 PM
twr's Avatar
twr twr is offline
Default Re: need help buying parts
Hi it costs alot to do that guessing about $1500 up. Alot of guys here have remove their air ride, to put coils in because of the cost to fix it.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-20-2010, 08:49 PM
i already have coil springs but i didnt liked them, noisey + riding quality is bad + ride height... thats why i wanna go back to the air suspension..
the guy that i bought the h2 from he installed tahoe springs and they fail, so its lowered now from the back... is there a good springs u recommend for this?
2003 Pewter H2
Old 09-20-2010, 09:09 PM
ok
gonna buy new coil springs that will make my ride height better .. is there coil springs designed specially for h2 ?
2003 Pewter H2
Old 09-20-2010, 09:22 PM
Hellz Hellz is offline
from the sounds of this, to clarify, you had the air ride system in before, and it was removed?
is the old compressor still there?
new one will run you about $800 from various sites.. ebay, 4x4 sites.. just search around, but thats about the average range
bags i have seen for about $90 to $150.
assuming you have all the hoses and conenctions still, it could be a simple re-install. if it was completly gutted, eh.. bring another case of beer to offset the time your going to spend figuring it out.
Old 09-20-2010, 09:48 PM
twr's Avatar
twr twr is offline
Hi these are replacement coils springs if the truck had air ride in it when new. Their is lots of companys out there that make a replacement spring this is a gm spring. Hope this helps.
http://www.teakatoys.com/Hummer_H2_Coil_Spring_Conversion_Kit_By_GM_facto_p /gm-springkit.htm
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-20-2010, 11:42 PM
Easy Ed Easy Ed is offline
Post about different places....
http://www.elcovaforums.com/forums/s...ad.php?t=38979
Old 09-20-2010, 11:48 PM
Easy ED: my ride height will be same as the air suspension? anyone tried them?
2003 Pewter H2
Old 09-21-2010, 12:07 AM
GM-25956182,GM-25956183,GM-15713853 x4
why right spring different than left ?
2003 Pewter H2
Old 09-21-2010, 01:08 AM
Sorry, didn't measure before and after. I have not noticed a difference though so it must be minor.
Old 09-21-2010, 01:12 AM
Difference in weight from one side of the truck to the other was our (forums) guess. Spare tire carrier would be one example.
P.S. It would be the tension of the spring and not the Over All Length that would be different.
Old 09-22-2010, 12:33 AM
i got the new coil springs and installed them, they're good but problem is there's noise when i ride on bumpers, when i take a u turn ... he didnt put a rubber he just put a piece of iron at the end...
2003 Pewter H2
Old 09-22-2010, 12:37 AM
twr's Avatar
twr twr is offline
Hi their should be 4 rubber isolators, top and bottom on both coils. If you don't have them the steel on steel is going to make all kinds of noise and will wear into the mounts. They must be installed!!!
15765071 $10.05 $0.00 $7.16
Rear suspension - Suspension components - Spring insulator
Spring insulator, hummer h2 2003 - 2009
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-22-2010, 04:56 PM
I'm in love with my H2 guys !
today, i taked it back to the shop, they removed the coils and installed the eom coils with 4 rubber isolators, ride height is cool now, and there's no noise ... fixed the windshield noise by selicon... no noise now ..
Installed a magnaflow catback ... my h2 now is just amazing .. thnx guys for the help ...
i'm going to install a transmission cooler next.
2003 Pewter H2
Old 09-22-2010, 08:32 PM
twr's Avatar
twr twr is offline
Hi glad it worked out for you and alot cheaper than fixing the air ride.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-23-2010, 12:15 AM
yeah it's true, the eom springs are great ...
what else to do guys, i'm looking for a cooler .. but don't know what to buy .. weather in my country is hot, maximum temp in summer is 140F minimum temp in winter 40F .. there's no snow .. so what the best cooler for my ride? do i need a thermostat?
2003 Pewter H2
Old 09-23-2010, 01:15 AM
twr's Avatar
twr twr is offline
Hi this is the best style to get and as big as you can fit in. Also you want to leave the rad cooler still hooked up and you don't need a thermostat with the temps where you live.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-25-2010, 04:11 AM
What would be your guess on cost be the then ?
Originally Posted by brandon mitchell
Yeah right!
