10-04-2010, 06:41 PM
How do I fix heated seats?
How do i fix the heated seats? I have a 2003 I just bought and the interior is new, but the seat heater is not working..
Any idea how to fix it?
Also, the headlights will not turn off in the off position....anyone have a fix??
Thanks for your help
10-04-2010, 10:22 PM
Re: How do I fix heated seats?
Anyone??
10-05-2010, 12:52 AM
I know how to fix them, problem is there can be anything from a broken wire to a failed module, switch, seat element, thermistor, fuse. No easy fix without actully looking at it
1998 Chev Z71
2007 Chev Trailblazer SS
10-05-2010, 01:54 AM
The light goes on in the door - driver and pass side. It just lights up for a second and goes dead. Fuse? That could be I'll check on the fuses.
Anyway you know of trouble shooting this? other than checking the fuses?
10-05-2010, 05:44 AM
If the light goes on then goes out that means its getting powered up, seeing a fault then shutting down. Wont be a fuse. I would guess thermistor or seat element. Spend a little money and have someone qualified check it out. Too tough to diagnose without the truck in my garage sorry
1998 Chev Z71
10-07-2010, 07:09 PM
I have the same problem. Let me know if you figure it out. I am looking into it as well.
10-07-2010, 11:54 PM
Heated Seat Inoperative
Step
Action
Yes
No
Schematic Reference: Driver Seat Schematics and Passenger Seat Schematics
Connector End View Reference: Power Seat Connector End Views
1
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
2
Operate the Heated Seat System.
Does the system operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
3 - <LI type=1>Install a scan tool. <LI type=1>Start the engine. <LI type=1>Display the Heated Seat Status and Zone parameters in the driver seat module (DSM) Input/Output data list.
- Operate the heated seat switch in all modes.
Does the scan tool display the correct Heated Seat parameters in relation to heated seat switch operation?
Go to Step 8
Go to Step 4
4 - <LI type=1>Display the Heated Seat Switch parameters in the door module Inputs data list.
- Press the head seat switches while observing the scan tool parameters.
Does the scan tool display the heated seat switches as active while the switches are pressed?
Go to Step 5
Go to Step 6
5
Do the heated seat switch indicators operate normally?
Go to Step 13
Go to Step 12
6 - <LI type=1>Disconnect the heated seat switch harness connector to the door module.
- Test the resistance through the heated seat switch from the voltage supply circuit terminal to the back only select switch signal circuit terminal while operating the heat level switch.
Does the back only select switch have continuity only when pressed?
Go to Step 7
Go to Step 10
7
Test the resistance through the heated seat switch from the voltage supply circuit terminal to the back/cushion select switch signal circuit terminal while operating the back/cushion select switch.
Does the back/cushion select switch have continuity only when pressed?
Go to Step 12
Go to Step 10
8 - <LI type=1>Disconnect the inoperative seat heater element connector. <LI type=1>Connect a test lamp from the voltage supply circuit terminal to the control circuit terminal in the harness connector.
- Operate the seat back and cushion switch to the high mode.
Does the test lamp illuminate?
Go to Step 11
Go to Step 9
9
Test the seat heater element voltage supply and ground circuits in the seat harness for an open or short to ground. Refer to Circuit Testing and to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 18
Go to Step 13
10
Inspect for poor connections at the heated seat switch harness connector to the door module. Refer to Testing for Intermittent Conditions and Poor Connections and to Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 14
11
Inspect for poor connections at the heated seat element connector. Refer to Testing for Intermittent Conditions and Poor Connections and to Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 15
12
Inspect for poor connections at the door module. Refer to Testing for Intermittent Conditions and Poor Connections and to Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 16
13
Inspect for poor connections at the DSM. Refer to Testing for Intermittent Conditions and Poor Connections and to Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 17
1998 Chev Z71
10-09-2010, 09:05 PM
The guy I bought the H2 from had the seats all reupholstered...
Maybe he removed the heating element. It has suede inserts in the middle of the seat....I'm guessing that is where the heating element is?
01-20-2011, 12:03 AM
Im having the same issue. But only when the truck is cold. If i hit the switch it goes on for a few seconds then off. I press again and the same....but as the car warms up each press seems to stay on a little longer till it just stays on like it should.
It has the Same behavior for driver or passanger seat...
Anyone find the solution?
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
01-20-2011, 02:43 AM
Sounds like one of the heater elements in the seat may have a partial open. As it warms up with your body heat the connection is made
1998 Chev Z71
02-28-2011, 04:52 PM
I have the same problem with a recently acquired '03 H2. Both Driver and passenger seat heater lights flash on momentarily and then off when you press either buttons on either side. I hear a little relay switch 'tick' when they are pressed, it sounds like it's coming from the seat heater box below the drivers seat. Your post will help me fix it I'm sure but I can't access any of the links from the tech site, it just says you don't have access. Is there anyway you can post those links/schematics? I don't want to buy any unnecessary parts and I don't want to pay somebody if I can figure it which parts may need replacing.
03-22-2011, 04:47 AM
Just purchased an '03. Same seat problem as you guys above. Push the front heated seats button and the light flashes once. Can hear the relay below. Rear seats work fine.
If you guys have found any fixes, I would greatly appreciate your update.
Cheers, J
06-15-2011, 08:14 PM
Update: Have taken the H2 into the shop. Turns out the problem is the actual heating element under the seat. All other systems/relays work.
New problem: GM parts department has informed me that the heated seats element for the H2 has been discontinued, and there are none available.
Any advice on hunting down a replacement element aftermarket? Haven't seen any on the internet. Does anyone know if I can use the element from a different vehicle?
Thank you,
J
06-16-2011, 01:01 PM
Not sure but maybe the heating element for a Escalade (Tahoe, Yukon) will work. I was amazed at how many shared parts the Escalade has with the Hummer.
07-05-2011, 03:47 AM
The Result:
Wanted to post a follow-up in case anyone came across the same issue.
Had a mechanic look at the seats, followed the electrical trail, problem was the seat heating element. Due to use/wear, the elements had fried. With one seat not working, it prevents both front seats from working.
Stupid GM design: the heating element is integral to the leather seat. Can't buy a replacement element alone. A new leather seat cover is $600 from GM, and that's if you can find one (no longer produced).
I was able to find a scrap hummer with matching leather. Swapped the seat leathers = warm bum!
Cheers, J.
04-01-2012, 01:20 AM
Hi, what do you mean seat leather? the whole seat ? or just the leather covers?
I have the exact same problem, 2 front seat, lights come on and goes off insatntly or after few seconds. Dealer said costs $7,000 to replace, I finally agreed but dealer later said no more parts available. Same story as above, one is broken, caused both to stopped working, back seats ok. I had the same original 2003 H2 since Oct 2002. Seat warmers worked fine for few years. All else work perfectly for almost 10 years 140,000 miles.
04-01-2012, 04:21 AM
Seat leather= the leather that wraps the foam on the seat.
As I mentioned in my previous post, the heating element is integral (part of) the leather.
Good luck.
