Old 10-04-2010, 09:23 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Default First Lifted H2
Just picked this up Friday. 4th H2, first one with a lift. Love it!
Old 10-05-2010, 05:09 AM
ROUSHDEMON's Avatar
Default Re: First Lifted H2
Nice lift!
get some bigger tires!
2003 Black H2:
2006 Blue H2:
Old 10-08-2010, 04:18 PM
Badace's Avatar
Badace Badace is offline
Badace is on a distinguished road
Screw up the ride? How bout performance? I need more geddy up. Pulling a trailer isn't the coolest either.
January 20, 2009, A Dark Day in American History. Tehee.
Sold. Miss u buddy.2006 SUV LE Demonguard and extras.
Looking
Old 10-11-2010, 02:57 PM
HumminNBoatin''s Avatar
Nice H2!
Looks a lil nekked though.... have to add a Treehugger to that bad boy!
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 10-11-2010, 06:52 PM
PaHumBug's Avatar
The steering/handling has def changed for the worse. The ride is pretty close to stock though. I think it was regeared because the power seems typical as well. It does have K&N air intake and superflow exhaust which probably helps too.
What's a Treehugger? Brush guard? I do want to do that, but I think power running boards are first...
Old 10-11-2010, 07:10 PM
Awe man.... you are breaking my heart with the "power running boards" aka.... I dont plan on offroading it.
Rubberduck 4x4 treehugger brush guard.
http://www.rubberduck4x4.com/store/p...rd-142p692.htm
Old 10-12-2010, 12:46 AM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
I have some shiny chrome, non-powered, step bars you can buy!
2004 white H2 SUV lux
Old 10-12-2010, 01:38 PM
PaHumBug's Avatar
I figured power running boards would be better for off roading because they tuck up underneath so the ground clearance is still there.
Old 10-12-2010, 05:23 PM
ROUSHDEMON's Avatar
Yeah if you go offroading in a sandbox!..... you will crush the h3ll out of them going over a good trail, I would love to have them if I didn't play every now and then with mine... its so freaking tall and it would look better without the OEM rails, but I would hate to spend $1k+ on rails that get crushed in the first trail.
..........Unless!......they came off really easy!
2003 Black H2:
2006 Blue H2:
Old 10-12-2010, 05:45 PM
PaHumBug's Avatar
Do you take your OEM one's off or just replace them when you crush 'em?
Where did you get your Demon Guard? I like the look of that better than the Tree Hugger.
Old 10-12-2010, 06:23 PM
ROUSHDEMON's Avatar
I take them off every time I got trailing, its only 8 bolts, takes 5mins
Oh the DemonGuards... Thanks ! I make the DemonGuards, I designed them.
Unfortunately my shop and house got flooded 4 months ago with 6 feet of muddy water, so right now its looking like I'll have it back up and running in January 2011 or hopefully before, if you can wait that long I'll make you one.
PM for more info.
Thanks again.
2003 Black H2:
2006 Blue H2:
Old 10-12-2010, 07:40 PM
PaHumBug's Avatar
PM sent
Old 10-13-2010, 02:05 AM
H200 H200 is offline
H200 is on a distinguished road
Looks great but might look even better with some bigger tires on it.
06 H2
05 H2
Ohio Hummer limos
Old 10-17-2010, 01:21 PM
HummerJim's Avatar
Nice H2! Larger tires are a toss up. I love the look and off roading with them, but I hate what it does to performance if you don't regear.
Old 10-18-2010, 05:06 AM
Bimmer9938's Avatar
Nice rig, what size tire is on it?
Old 10-18-2010, 03:39 PM
PaHumBug's Avatar
Those are 37's
Old 10-18-2010, 05:20 PM
Bimmer9938's Avatar
Is the front cranked higher than the rear? I think that the 22" Rockstar he is running is just a really high offset, if it was a lower offset and they stuck out more the tires would not look as small. Still looks goood none the less.
Old 10-18-2010, 06:06 PM
PaHumBug's Avatar
I don't know how to tell if he cranked the torsion keys (can I tell by looking?), but it sits pretty level. The Fabtech lift pushed the front wheels out 1.5" on each side as well.
Old 10-18-2010, 09:49 PM
Bimmer9938's Avatar
Yep look under the crossmemember towards the middle of the vehicle, you will see where the torsion bar connects from the lower A arm up front to the torrsion key in the crossmember, there will be a bolt threading into a steel shank that goes against the torrsion key. If the bolt is threaded all the way in (or close to all the way), you know they are cranked.
