10-06-2010, 01:34 AM
Lights won't go off in Park?
Any idea how to get the light to go off in the park position or even while driving?
I had a 07 and the lights you could manually shut off, but no I have just purchased a used 2003 H2 with after market Nav and dvds. So wiring must have been messed with.
Anyways, I need to figure out how to get the lights to turn off........like if i am in a driveways and the light are shinning right in someone house and I want to shut them off.......Any ideas?
Any suggestions will help.
Thank you
10-06-2010, 03:15 AM
Re: Lights won't go off in Park?
Turn them from Auto to on then all the way to the left past Auto... should turn them off.
2003 Black H2:
2006 Blue H2:
10-06-2010, 03:35 AM
Yes sir, that should turn them off, but it does not work. That is my problem.
10-06-2010, 03:52 PM
oh wow.... hmmm.
There is no way of telling then, there has got to be a switch or something for them. Try playing around with the computer and tell them to turn off as soon as you turn the engine off, no Delay on them. I dunno.... something has to work. Good luck.
2003 Black H2:
2006 Blue H2:
10-06-2010, 05:36 PM
oh wow.... hmmm.
I need a programmer for that....which I don't have
But thanks for your help RoushDemon.
I think the electrical has been all screwed with. I has after market nav and dvds....I think they messed with the wiring. I may bring it to the dealer
10-06-2010, 09:01 PM
Do your steering wheel volume control buttons work?? with the aftermarket DVD/Radio? if they do then there should be a green wire connected somewhere underneath the steering column feeding off of one of the cables that goes up to the steering wheel... Play with that and see if its not connected to the right cable or MAAAAAAAAYBE its connected to a cable that controls the headlights, the devise that makes that aftermarket radio work has its own power source and it might be messing with something its not supposed to, I would even go in the outside fusebox in the engine bay and see if there is no cable in between any fuses as if they're making your DRLs work along with the headlights, might be making a short? I dunno, good luck bro.
Tracy, you got any ideas???
2003 Black H2:
2006 Blue H2:
10-18-2010, 11:03 PM
oh wow.... hmmm.
10-19-2010, 03:21 AM
Originally Posted by davidwillson
oh wow.... hmmm.
OKay, one problem solved with the computer I got the lights to go off in the park position as soon as i turn off the engine and pretty much remove the key. As lone as the key is in the off position the lights go off.
I know its from Canada (Canada H2's you can not turn off the drl's) and HUMTECH was right - i think the lights have been jumped from the DRL to the headlights. Sometime I can turn them on and off other times they are just on all the time...no turning them off.
Anyways, I will figure it out eventually.
Hybrid Mode
