Old 10-15-2010, 11:48 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Demans sucking my H2's Life
I know this has been discussed before, but I have not seen anyone post an answer to the mystery.
If I leave my H2 for a week without starting it, the battery goes completely dead.
Anybody have any ideas?
Old 10-15-2010, 12:51 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
Default Re: Demans sucking my H2's Life
I had the same problem with my H2 and it's even worse with my H3. After trying different batteries and cables I installed a CTEK charger. I have it plugged in whenever I'm not driving it. It works great, no more problems!
2008 H3 Alpha - Boulder Gray
Old 10-15-2010, 02:51 PM
SmokeyJoe's Avatar
Now thats an idea but what a pain. I may have to resort to this, but I wish I could just fix the issue.
Old 10-15-2010, 11:09 PM
HUMMERICH23's Avatar
HUMMERICH23 HUMMERICH23 is offline
HUMMERICH23 is on a distinguished road
Had the same problem over a year ago. what a pain in the azz it was. My truck was at dealer for about 3 wks to figure it out and GM/Hummer sent people down to figure it out. About once a week in the middle of night, something would turn on and run at about 300amps just killing the battery in a minute. I posted on here about while it was at dealer and got a lot of help from everyone. I used the ideas i got to give to GM. Sadly they couldn?t figure out exactly what was turning on ! They had all this equipment on it (looked cool) and still couldn?t figure it out. So they completely reflashed all the computers (after i gave them the idea) PCM/BCM/TCM/ onstar update, radio, etc and it worked! No problem since! I did install an OPTIMA D31A since i wasn?t crazy about my battery being drained tons of times by the dealer and not replacing it saying it was fine. So i was like whatever, ill go get a bad azz battery. Got it for 190 shipped to my door with coupon from advanced autoparts.
COMMERCIAL YELLOWTOP DUAL PURPOSE BATTERIES
MODEL NUMBER D31A & D31T
PERFORMANCE
Voltage 12V
Cold Cranking Amps @ 0 F 900
Cranking Amps @ 32 F 1125
Reserve Capacity 155
Capacity (C/20 rate) 75
Internal Resistance (ohms) 0.0025
PHYSICAL SPECS
Length 12-13/16"
Width 6-1/2"
Height 9-3/8"
Minimum Weight (lb) 59.8
Type/Post Terminal 3/8" Stainless
Steel Stud & SAE Post
BCI Group 31A & 31T
Richard
Old 10-16-2010, 12:51 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Is your onstar system active? If not try pulling the info fuse and try it. When you dont have an onstar subscription sometimes the module will wake up randomly and attempt to find a sat signal.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 10-16-2010, 07:45 AM
SmokeyJoe's Avatar
I pulled the OnStar fuse along time and it has done nothing for.
My problem is I am in Germany and there is no deler support for me. There is a guy near by who could do it but at my cost.
