Old 10-23-2010, 10:19 PM
EastTexan EastTexan is offline
EastTexan is on a distinguished road
Lightbulb Stock Hummer H2 Off Road Lamp Hardware
I have a pair of OEM HUMMER H2 round off road lamps with NO hardware. I also have the OEM brackets to mount the lamps to my OEM brush guard.
I need the U-shaped brackets and hardware that attach to the the lamp body.
I tried using brackets off a cheap pair of lamps I had laying around, but they do not really hold the HUMMER lamps securely.
The HUMMER lamps have some "teeth" inside the bolt channel, presumaby as detents to hold the aiming position more securely.
Do any of y'all have an old, even damaged pair of OEM H2 round lamps or just the lamp brackets available? Or do you know a different brand of lamp that has the same style lamp brackets/hardware? Any other ideas? Thanks.
Old 10-23-2010, 11:52 PM
twr's Avatar
twr twr is offline
Default Re: Stock Hummer H2 Off Road Lamp Hardware
Hi warn makes a light bar that mounts to a stock bush bar then maybe you don't need the u clamps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 10-23-2010, 11:54 PM
twr's Avatar
twr twr is offline
hi here is a pic. i thinks its about $190 it would be better to find the u clamps you need, but this is a option.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-24-2010, 01:09 AM
Arrow Re: Stock Hummer H2 Off Road Lamp Hardware
Thanks, but that would still not solve the problem I described. I have the lamps but NO hardware to mount the lamps to ANY bracket, tube, adapter, bar, etc. There is no hardware attached to my lamps - just bare lamps. If I had complete lamps, I could just bolt them to the existing brackets.
Also, I want to use my existing OEM brush guard mounted lamp mounts, one reason being the WARN light bar is incompatible with the WARN winch bumper, should I ever decide to install one. Also, I prefer the OEM look of the factory option brush guard mounted off road lamps.
As an aside, I do have the Aries light tab you alluded to, which mount lights to a brush guard tube, but I still just have bare lamps, and no way to mount the lamps to the Aires tabs.
I know, I could just buy some PIAA or KC lights and bolt them right up to the factory brush guard mounted off road lamp brackets, but I already have the bare OEM lamps with HUMMER covers.
Old 10-24-2010, 01:49 AM
twr's Avatar
twr twr is offline
Hi I think i get it now their is no stud or anything to mount them. Do you have a picture so i can see maybe what your looking for and i will sreach for it on the net or maybe i can make what you need.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
