Old 11-02-2010, 08:31 PM
Poppabear_093 Poppabear_093 is offline
Poppabear_093 is on a distinguished road
Red face service 4WD
04 H2 69k and suddenly the service 4WD light comes on and the 4WD light on the dash flashes, but not everyday. ???? I'm trying to get an idea before the dealer soaks me
Old 11-02-2010, 10:19 PM
H2 Bill H2 Bill is offline
Default Re: service 4WD
I had the same thing happen this summer. Put it into 4low and drive it around a little bit and 4 lo lock and do the same. It's from lack of use in low range.
1994 Chev Suburban Blown
Old 11-03-2010, 01:44 AM
06 SUT 06 SUT is offline
06 SUT is on a distinguished road
I had the service 4WD come on and now I cannot shift into 4LO. I don;t have any codes popping up right now but will try it again when it comes back on. If you resolve this, shoot me some information if possible.
Old 11-03-2010, 01:05 PM
HummerMann's Avatar
I've had this light once in both of my H2s. In the '03 it was solved as per the dealer suggestion of shifting from 4L to 4H 15 times - does something to the contacts in the transfer case. When my '06 got the light I tried the same thing and it didn't work and the dealer found my 4L switch had gone bad on the dashboard.
Hummer, like nothing else
Old 11-10-2010, 02:49 AM
liquid0 liquid0 is offline
liquid0 is off the scale
I had exact same issue and ended up having the dealer fix it. Ended up being the switch as well. At first it was intermittent but then the light on my dash kept going out and and after trying all the suggestions, I took it in and they replaced the switch. I think it was ~$350
Old 11-29-2010, 07:50 PM
Thanks, That was it!
