Old 12-15-2010, 01:55 AM
myrddin myrddin is offline
myrddin is on a distinguished road
Default H2 Oil Gauge
Can you guys do me a favor? I need to know when your H2 is sitting and not running at all what is your Oil pressure gauge showing for a reading. I seem to never go to 0, and I think that is odd. Also I see that it will reach almost 80 PSI when I accelerate, but at cursing speed (about 60) it sits on about 50-60 PSI. However when shut off (no key in the ignition) it shows about 20 psi.
Now with that being said does the H2 have a gauge test that will reset the gauges? I have had some cars/trucks where you can do something and the gauges will sweep a few times and then reset.
Thinking the oil gauge has somehow gotten set at 20 psi while thinking that was 0???
I have read the threads showing that the needles were stuck and so on, but this one moves...
I topped off the oil the other day and noticed it the first time (may have been like that for a long time) but just curious...
Old 12-16-2010, 04:47 AM
Ice Ice is offline
Ice is on a distinguished road
Default Re: H2 Oil Gauge
I have 2008 H2. When the engine is off it is at 0.
Ice Ice is offline
Old 12-16-2010, 01:55 PM
OK... as I figured it should be. It must have moved. But still works... at least it is in motion as I drive.
odd
