Old 12-15-2010, 04:25 PM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Default Need to buy a wiper motor and module. Where from?
Well the wipers are sounding very tired,and it continously dumps washer fluid on the rear screen. Anyone know where i can buy the complete unit of motor and module?
Old 12-15-2010, 09:24 PM
Easy Ed Easy Ed is offline
Default Re: Need to buy a wiper motor and module. Where from?
Try GM Parts Direct at http://www.gmpartsdirect.com/ ????
Go to the "catalog" tab on the home page, agree to "terms and conditions" in the next window, enter truck info and go to the "Windshield" section then be prepared for sticker shock....Wiper Motor $217.21 Module $156.78 for a 03-07 model year.
Edit, oops, just seen you are in the UK, don't know if they will ship, sorry if not.
Ed
Old 12-16-2010, 07:03 AM
Ok. I will give them another look and maybe contact them direct. The only thing thats put me of them,is that the catalogue diagrams of the wiper motor and module bear no resemblance to the actual wiper motor and module. Its a long way to ship back and costly if its wrong.
Old 12-16-2010, 11:05 AM
Never looked at the diagram while looking it up and making the post but I did this morning and you are correct, it doesn't look the same
Does say at the bottom that you should....
Before proceeding with check out, please confirm part number with our customer service at customerservice@gmpartsdirect.com Parts ordered without confirmation are not eligible for return.
Good luck, Ed
Old 12-21-2010, 07:02 PM
Just to bump this back up. Ive sourced a remanufactured wiper motor from Rockautos. But i cant locate a module. Ive had no joy with GM parts direct getting back to me with an e-mail confirming if they stock one or not. I'm appealing to my fellow Hummer brethren for any help with this. As next month the vehicle will need an m.o.t to be used on the road. If the washer jets dont work then i wanted be granted an m.o.t and wont be allowed to use it on the road. Mark
Old 12-21-2010, 11:20 PM
[__--MUD--__]'s Avatar
If your just concerned about the washer dumping fluid on the rear window and the wipers motors are still functioning, you dont need to replace it. I'm betting it dumps the washer fluid when you hit the brakes...
Do a search off my username, I made a post about water getting in the motor assembly. Basically pull off the airboxes, and panel, pop off the bottom cover on the motor where the wire harness plugs in and take out the board. There will be carbon tracks from water directly tracking across the lowest point on the board. Clean that **** off, glop the board up w/ some electrical grease over all the components and put it back together w/ some silicone. Problem solved.
Old 12-22-2010, 12:09 AM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
this is an old post but over the last few days here in CA we have had severe rain... wipres acting up... only fast speed, and water dumping out at rear screen.
vehicle was parked front upwards in drive way so suspected rain in motor or something.
pointed nose downward over night and wipres starting working again.
but as soon as i put ignition on water dumping out at the back.
took out relay to stop water .. wipers seem ok but no front washers.
tried to find your post about strip down has it been moved?
thanks
Old 12-22-2010, 02:49 AM
must of posted my pics of the tear down on another site.. Pretty much the same as this post, but I had a few more pics than Easy Ed -
http://www.elcovaforums.com/forums/s...ad.php?t=29583
The straight side of the board opposite/back side is where you will find the problem, its the lowest point, should pull out of the housing....I know I completely removed the board to clean it and seal it up. I actually had carbon tracks like in an old distributor on mine.
If you have an 05+, there's a recall specifically for this reason.
Old 12-22-2010, 08:09 AM
I think mine really has had it though. I followed some of the threads on here regarding the trouble with the module. I stripped mine out. Cleaned up the circuit board,re-sealed. Everything was fine for a few weeks. Then i got the fluid pumping out the rear as soon as i touched the ignition. Ive now left the fuse out altogether.
Old 12-22-2010, 06:58 PM
Did you actually coat the board in some type of electrical grease? Or just seal up the box? If you did, you should be able to damn near submerge the board in water and it will still work.
Old 12-28-2010, 02:14 AM
<<< I would appreciate the recall if you can get a hold of it... I am going to call my local dealer. I am out of warranty with 72,000 miles but worth a try.. the cluster has also started acting up....never ends >>
THANKS
Old 12-30-2010, 11:55 PM
Desperate now for a supplier of the module. GM parts direct do not ship outside the U.S and Rockauto,s do not stock the part. Does anyone know of anyone else that would hold the part and who do ship internationally???.Really desperate now.
Old 12-31-2010, 04:13 AM
twr's Avatar
twr twr is offline
Hi these guys will ship to you here is a link to their website and a link to shipping policy.
Link to website:http://www.buygmpartsworldwide.com/p...?siteid=215130
Link to shipping policy:http://www.buygmpartsworldwide.com/storefront/index.cfm?action=viewAllPolicies&policy=2&siteid=2 15130
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 12-31-2010, 08:35 AM
Tracey thanks once again for your help.
Old 12-31-2010, 11:55 AM
twr's Avatar
twr twr is offline
Hi your welcome. I have bought from them before with no problems. If you call them ask for INTERNET PARTS SALES and talk to John Z that is who i deal with, he is very nice. They may not have it in stock but can usally get stuff in a week or so.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 01-03-2011, 01:49 AM
Well i ordered the part today. Cover including the circuit board. Cost was $72.Hopefully this should sort my wiper problems. TWR thanks for the link.
Old 01-03-2011, 05:20 AM
twr's Avatar
twr twr is offline
Hi did you phone and talk to John or just order on the internet?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 01-03-2011, 06:11 PM
I tried calling over the weekend. But i couldn't get an answer. Guess they dont work weekends. Ordered from there site in the end.
Old 01-09-2011, 01:13 AM
kmleong kmleong is offline
kmleong is on a distinguished road
I think that i have the same problem as you, same symptoms anway. Do you have a part number? I looked on the link and came up with $188.44
2004 H2 Lux; Night vision, Helix Tower power 11, Volante CAI, Diablo Predator, Bluestar, 20" Weld Racing, 325/60 Terra Grapplers, Rancho 5000's + Steering Stabilizer, XTC Lightbar,Hella driving lights, Compustar Alarm + Remote start, 2 Elec. fans, Tru cool 4739, oem Rear camera,console vault
Old 01-09-2011, 02:47 AM
Yeah sure. Its #19120103. It should list it as cover. I had a confirmation e-mail back to ay it was for cover including (circuit board).
