Old 12-20-2010, 12:13 AM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Default Engine oil life reset?
I'm just about to change the oil and filters. Once done how do i re-set the oil life? Also what spark plugs do i need? Still no nearer to sourceing a wiper motor and module. And at the moment i do need one. Lots of snow here at the moment.
Old 12-20-2010, 02:51 AM
twr's Avatar
twr twr is offline
Default Re: Engine oil life reset?
Hi this is for a 2003 h2
GM Oil Life System
Press the fuel information button until ENGINE OIL
LIFE appears in the display. The GM Oil Life System
shows an estimate of the oil?s remaining useful life.
It will show 100% when the system is reset after an
oil change. It will alert you to change your oil on a
schedule consistent with your driving conditions.
Always reset the engine oil life after an oil change.
To reset the Oil Life System press and hold the select
button for five seconds while ENGINE OIL LIFE is
displayed. OIL LIFE RESET will appear on the display
for 10 seconds to let you know the system is reset
The DIC does not replace the need to maintain your
vehicle as recommended in the Maintenance Schedule
in this manual. Also, the oil change reminder will not
detect dusty conditions or engine malfunctions that
may affect the oil. Also, the oil change reminder does
not measure how much oil you have in your engine.
So, be sure to check your oil level often. See ?Engine
Oil? in the Index.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 12-20-2010, 02:58 AM
Thanks TWR. Any ideas on what the correct plugs are to use?.
Old 12-20-2010, 03:06 AM
twr's Avatar
twr twr is offline
Normal Maintenance
Replacement Parts
Oil Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PF44*
Engine Air Cleaner/Filter . . . . . . . . . . . . . 88944151*
PCV Valve . . . . . . . . . . . . . . . . . . . . . . . . . CV948C*
Spark Plugs . . . . . . . . . . . . . . . . . PTZ16R15 Denso?
PZTR5A15 NGK?
Fuel Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . GF626*
Wiper Blades (Front) . . . . . . . . . . . . . . . 15706394**
Wiper Blade Type (Front) . . . . . . . . . . . . . . . . . ITTA
Wiper Blade Length (Front) . . . 22.0 inches (56.0 cm)
Wiper Blades (Rear) . . . . . . . . . . . . . . . . 15174476**
Wiper Blade Type (Rear) . . . . . . . . . . . . . . . . . . ITTA
Wiper Blade Length (Rear) . . . . . . 11 inches (28 cm)
* ACDelco Part No.
**GM Part No.
? Spark Plug Gap is 0.060 inches
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 12-20-2010, 05:02 AM
Thanks once again.
Old 12-20-2010, 10:31 PM
twr's Avatar
twr twr is offline
Hi no problem, glad i could help.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
