Old 12-26-2010, 07:02 AM
bchas92097 bchas92097 is offline
bchas92097 is on a distinguished road
Default Programmer Help
I am looking to add a programmer to my 2008 Hummer H2. I was also wondering if it would help with the sluggish start off in it. It is sluggish under 2500 rpm. I also think that it might help if I can change the tire size also.
Old 01-03-2011, 03:30 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Re: Programmer Help
I would not be looking for any huge improvements, but I believe it woudl help you some.
You could adjust for tire height
You could adjust shift points/pressures
You could tune for performance which adjust the fuel/air ratios.
Worth a try, they dont cost much anyway.
If your running huge tires, you probably want a regear.
But still the programmer would be needed to get the speedo corrected after modding tires/gears.
