Old 01-01-2011, 07:24 PM
DRZDuke's Avatar
DRZDuke DRZDuke is offline
DRZDuke is on a distinguished road
Default Air Suspension Woes
I just had a new ride height sensor and Air system Module installed my H2.
All seems to be working as it should, however, when I shut the truck off for any more than 1/2 hour, the rear air seems to bleed down.
As soon as I fire the truck up, compressor kicks in and pumps up the Hummer as per usual but it didn't operate this way before I had the issue with the suspension.
Is this a programming issue ? The tech that replaced the electrical components assured me there were no leaks in the bags(which I replaced last year)
Any help would be great.
Old 01-02-2011, 04:07 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Air Suspension Woes
Has to be a leak. Use the extended ride height button to raise the rear of the truck and spray the bags with soapy water. May have a leak at the base of the bags which would not be seen at normal ride height.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-03-2011, 10:37 PM
trofeo16 trofeo16 is offline
trofeo16 is on a distinguished road
I'm having the same problem, Just swapped out my single stag efor a dual stage. After a few hours the rear end sags. If the bags or one of the lines were leaking than wouldn't only one side of the truck sag?
