Old 01-07-2011, 12:29 PM
06 SUT 06 SUT is offline
06 SUT is on a distinguished road
Default Air Suspension
I need a little advice about the compressor for the suspension. Got home last night and the the compressor would not shut off after the truck shut down. I had to pull the relay out to cut it off. The rear does not seem to be sagging but I will check it out in the am. If the rear is not sagging, where should I look for the issue. I understand if it is sagging, look for an issue that caused the bags not to inflate.
