Old 01-09-2011, 07:18 PM
myrddin myrddin is offline
myrddin is on a distinguished road
Default Front Hub Replacement Help (what do you think)
Hey guys, I am going to get some parts I need for repairs. I have an odd knock in the driver?s side front under my feet when I turn sometimes sounds like something slapping the floor at times, I suspect a body mount... However on the other side I seem to have a bit of play in the up and down (vertical) movement of the wheel and when I am turning left I get an embarrassing howling noise... This I suspect to be the Hub.
To get to the point. I have found a deal on two hubs for a bit over 200.00 and you get a few lifetime warranty.
See info:
BUY FROM MAC AUTO & GET THE MAC DOG WARRANTY , LIFETIME ON ALL OUR Wheel & Hub Bearing Assemblies
This item is for TWO BRAND NEW OEM style replacement Wheel & Hub Bearing Assemblies for the Front of your Car , Truck , Suv
FITS
* 2003,2004,2005,2006 HUMMER H2 All Engines
INCLUDES
* PART # 515058 PTC
ALL OF OUR HUB & BEARING ASSEMBLIES FEATURE
* 1/ HIGH QUALITY OIL SEAL
* 2/ INTEGRAL RACEWAY. TO PROVIDE PROPER BEARING CLEARANCE
* 3/ OEM APPROVED DESIGN
* 4/ OEM ABS SENSOR AND PLUG , AND ALSO ABS TRIGGER WHEELS WHEN REQUIRED
* 5/ LIFETIME WARRANTY FOR AS LONG AS YOU OWN YOUR CAR
Will this work for me? I figure even if they only last 3 years I may get another set free to fix down the road...
Please let me know, I would like to order and be done with it.
thnx guys.
