Old 01-27-2011, 03:29 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Default Alternator options
Hi all,
I'm going to replace my alternator. 145 amp OEM from GMpartsdirect cost $230, eBay has $200 amp alternators (they say they fit H2) for as low as $120.
What is the advantage of the 200 amp? Is it necessary?
Do you see any risks with 200 amp AND/OR non-OEM? It's pretty tempting at half price...
Old 01-27-2011, 04:40 PM
Hellz Hellz is offline
Default Re: Alternator options
well you need to find out more about the alt.
for example
200 amp may actually produce 200 amps, but at 5000 RPM.
at idle it may only produce 100 amps..
as for the OEM 145 amp.. i do not have the specs on it, so i cant give you a comparison.
most likely, the 200 amp only will produce the full 200 amps somewhere about 1200 rpm to 1800 rpm, which is prefectly fine.
you are also looking for somethign that produces 14.5 volts there or abouts.
the benefit is you can run more toys without worries of taxing your system.
Old 01-27-2011, 08:04 PM
PaHumBug's Avatar
Here is what I am told about the one on eBay: It is 120-130amps @ idle and 200-220 amps @1200 rpm.
Old 01-27-2011, 08:27 PM
i have seen this ad before for this Alt.
as long as it will month up to the engine. you may have to pull the pull off the old one and put on the new one so the sepr belt fits to it.. you should be good
Old 01-28-2011, 06:09 PM
IRA51's Avatar
IRA51 IRA51 is offline
FYI if you have an old time Alternator shop around they can rebuild yours for $85.00 or so to be better than stock with a new regulator and bearings .You will save freight and a properly rebuilt Alt is as good as a new one . I have been useing Bills auto eletric in Phoenix for 30 years to rebuilt Generators and alternators with great results .
A government big enough to
you have.
-- Thomas Jefferson
Old 01-31-2011, 09:01 PM
HumminNBoatin''s Avatar
Yeah IRA exactly right. I did this with my boat alternator and saved about $250! Cost me like $75 to have it rebuilt.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
