Old 02-04-2011, 04:52 PM
Bulldog400 Bulldog400 is offline
Bulldog400 is on a distinguished road
Default 03/04 rear end Question !!
Will an 04 H2 rear end work in an 03 H2. If not what will need to be changed out to make it work. I need an answer ASAP im going to look and buy the rear end tomo. Thanks, Rob
Old 02-04-2011, 05:03 PM
Hellz Hellz is offline
Default Re: 03/04 rear end Question !!
im sure more of an expert will chime in, but yes it will.
03 to 06 are baiscally identical trucks. some parts maybe have been changed with different parts over the years to resolve or fix some issues.
but for the rear end.. im assuming you mean the rear axle/Diff.. yes.
actually almost everything will work from H2 to H2 within those years.
if you dont mean the axle/Diff.. please provide more info on wxactly what you are looking for
If it is for a Diff.. the main thing would be to make sure its the same gearing as your front end. 4'10 is stock, but who knows what you did to your H2 and what the owner did to that rear end your going to buy.
Old 02-04-2011, 08:48 PM
Yes!! Its the whole rear end out of an 04 with 35k miles on it. Thanks I'll let you know how it goes.
Old 02-04-2011, 09:02 PM
then yes, everything should bolt up the same.
now if one has the air ride suspension and the other doesnt.. i dont know if that will have any play
Old 02-04-2011, 11:33 PM
No !! Neather has the air ride. My brother thanks becouse of the non factory(full posi) rear end is what makes the front end feel like its binding when turning sharp. I sure hope this will fix my rig.
Old 02-05-2011, 12:51 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Really? sounds more like the t-case is not shifting out of 4hi lock to awd
1998 Chev Z71
2007 Chev Trailblazer SS
Old 02-06-2011, 04:04 AM
How right you are!!! New rear end same problem. Droped t-case out and going to open it up on monday. Looks like I now have a spare rear end.
Old 02-07-2011, 05:10 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
I would agree with Humtech... Problem in the t-Case.
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 02-07-2011, 05:42 PM
Thanks for all the information. Opened the T-case this morning and the shift fork was broke. I have a new one on order and should be back on the road this week-end.
