Old 02-11-2011, 10:03 PM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Default Air intake and exhaust help gas mileage?
I have an '08 SUT and my CPU currently reads around 10.5 mpg. The only upgrades I have are wheels and tires. I have read where some guys have the same rig and get around 12-14 mpg. Every time I fill up my fuel range is around 275-280 miles, which is terrible. Would adding an air intake and exhaust possibly help gas mileage, even just a little bit?
Austin
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 02-11-2011, 11:34 PM
twr's Avatar
twr twr is offline
Default Re: Air intake and exhaust help gas mileage?
Hi if you changed the tire size [diameter] from stock size [diameter] the speedo and the odometer will not be reading correct and the trans will not be shifting the way it should either. The instrument panel cluster (IPC). displays the vehicle speed as determined by the ECM. You need to have it reprogramed with the correct tire diameter then it will give the correct odometer and speedo and trans shifting. Also after the reprograming is done that will make your milage computer correct. The dealer can reprogram it or it can be done with some hand held programmers like Daiblo sport or superchips. Hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 02-12-2011, 12:11 AM
twr's Avatar
twr twr is offline
Hi this should help you understand the different tire size
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 02-14-2011, 01:12 AM
tyler1bo's Avatar
Thanks for the input. I will look into that.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 02-14-2011, 05:42 AM
twr's Avatar
twr twr is offline
Hi your welcome, my 2008 only has different tires the rest is stock and i get 11.5 to 13.5 mpg depends how i drive. I do us a diablo sport programmer with the 87 oct program.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
