Old 03-11-2011, 07:38 AM
Default LED Lighting w/ Lower Grille
Sneak Peek of the Custom Rigid Light Bar in the lower grille.
This will be a kit you can purchase for the H2's for 03-07. I have not looked at the deisgn behind the lower grille on the 08-09 yet. But I know the lower grille is different.
I got the spacers designed/ made today, templates made for the 2 holes that need to be drilled, and mounted it up. I have to do a full install guide with pics yet.
* Rigid Ind LED bar was cut to the specification I requested.
* It fits like a glove with enough room around it for through airflow/proper cooling, light output without shadowing.
* Roughly a one hour install is what I estimate once the kit is completed.
* You do have to dremel out the lower grille, but the lines are so easy to do and that plastic gets cut like a hot knife through butter.
* Hinges with the hood also. So you don't have to remove that bumper.
* Sits back far enough you won;t smack it on stuff either.
