03-21-2011, 04:09 AM
Air Suspension to Spring Lift
I want to lift my 03 H2, which has rear air suspension. But I want a lift kit that uses springs. Do I need to swap the airbags for springs before I lift it or can I just use the springs for the lift kit to swap out the airbags?
2003 Hummer H2
03-21-2011, 06:44 PM
Re: Air Suspension to Spring Lift
Hi just much sure you tell the company that you buy the lift from that your truck has air ride on it now, so you get the right rear springs.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
04-16-2011, 06:56 AM
I had to swap over to springs when my compressor crapped out. I bought from Suncore Industries and I remember seeing a spring conversion w/ lift option. It's a quick fix if you have the proper rolling jack and stands. Good Luck.
04-23-2011, 10:12 PM
Good move, I had to do the same. Better to have hardware back there then airbags anyways, less electronic problems to deal with over time. Can't really pop or have issues with a steel spring.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
04-24-2011, 05:25 AM
Dont waste your money replacing the bags if you're getting a lift kit down the road...you'll swap them for the kit springs anyways, just do it all at once.
2003 Black H2:
2006 Blue H2:
