Old 03-22-2011, 03:30 AM
Joe Joe is offline
Joe is off the scale
Default Parasitic Draw - usual suspects?
Well. from my previous post I've been fighting a dead truck for about a week.
Decided this weekend to replace the battery and also had the Alternator fail the regulator test. FIgured between the two I would easily solve the problem. No such luck. Came out today and dead again.
Suspect at this point it has to be parasitic draw. Any thoughts on some of common suspects for this. I do realize it could be just about anything.
I just pulled the fuses tonight for radio and onstar to start the process.
Thanks again all.
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 03-24-2011, 09:39 PM
[__--MUD--__]'s Avatar
Default Re: Parasitic Draw - usual suspects?
any accessories connected directly to your battery, not going through stock wiring?
think it was back on my 1st power issue, since I had a brand new HID light setup connected directly to the battery, I assumed it was good. I was testing **** for days...by chance buddy of mine noticed the headlight realy was warm... That was my draw. My point is dont assume anything, test it all and keep the variables consistent.
Old 03-25-2011, 07:18 PM
Joe Joe is offline
thanks. I pulled the radio, radio sub, and info fuses and its been good for the last three days. Planning to dig deeper in to it this weekend but hoping its the Onstar as that's an easy one since I dont use it. Little concerned though that it is the radio. It was acting funny beforehand in that it was getting horrible reception when it shouldn't have.
2001 H1 Opentop
2003 H2
Homepage:
Old 03-25-2011, 07:52 PM
Are you actually taking any amp readings or just pulling ****? What draw are you getting right off the battery?
You need a good digital auto rangine meter to do this. When you first turn the truck off it will be in a higher amp range, which will drop down to a lower range after 10 minutes or so. If your not sure what your doing, you'll smoke your meter.
Someone posted the mah draw numbers a while back on all the common circuits that retain power when the vehicles off...I used it tracking down my issues. Might of been Easy Ed.
Did you try searching the forums for "parasitic"?
Old 03-25-2011, 10:00 PM
Joe Joe is offline
Just pulled the fuses (one's often the most suspect) at this point as I was out of town for work this week. Really just wanted to take a swing and narrowing down the problem. I do have a fuse tester/meter as well as a multimeter and will dig deeper over the weekend.
2001 H1 Opentop
2003 H2
Homepage:
Old 03-26-2011, 04:24 PM
Joe Joe is offline
Looks like the Radio is indeed suspect.
Radio Fuse is pulling 1.1-1.2A key out, no power to truck
Radio Sub is also pulling 1.0-1.1A key out, no power
I am guessing this pull is out of bounds...
2001 H1 Opentop
2003 H2
Homepage:
