Old 03-24-2011, 01:43 AM
CALIH2O's Avatar
CALIH2O CALIH2O is offline
CALIH2O is on a distinguished road
Default TAIL DRAGGING STUCK IN MAMMOTH HELP!
HEY GUY'S NEED HELP, AIR SUSPENSION WENT OUT ON SKI TRIP TO MAMMOTH WITH FAMILY. CHANGING OVER TO OEM COILS ON FRIDAY, PARTS ON ORDER. MY QUESTION IS HOW DO I RE-FLASH THE COMPUTER SO THE SERVICE AIR SUSPENSION LIGHT GOES AWAY ONCE THE COIL SPRINGS ARE INSTALLED? i HAVE SEEN SOME DISCUSSION IN REGARDS TO THIS BUT WOUL APPRECIATE GREATER DETAIL FROM SOMEONE WHO HAS DONE THIS SO I CAN PASS THIS ON TO THE MECHANIC PERFORMING THE COIL CHANGEOVER. ANY HELP WOULD BE APPRECIATED.
THANKS,
CALIH2O
Old 03-24-2011, 02:02 AM
Easy Ed Easy Ed is offline
Default Re: TAIL DRAGGING STUCK IN MAMMOTH HELP!
Couple ideas, http://www.elcovaforums.com/forums/s...ad.php?t=38543
Old 03-24-2011, 03:01 AM
CALIH2O's Avatar
THANKS EASY ED, STILL NOT SURE WHAT IS THE CORRECT WAY TO DISABLE THE AIR SUSPENSION CODE. PLEASE BE MORE SPECIFIC IF AT ALL POSSIBLE. IS THE RELAY THE WAY TO GO OR IS THE REFLASH?
Old 03-24-2011, 03:11 AM
fllaw1 fllaw1 is offline
fllaw1 is on a distinguished road
If you follow Easy Ed's post it worked for me. I disconnected the battery cable did the swap over and pulled the relay and have not had a light come on. You may also disconnect at the compressor to but depending on far of the removing process you want to do.
Old 03-25-2011, 04:00 AM
H2005's Avatar
H2005 H2005 is offline
H2005 is an unknown quantity at this point
Does it look like this in Mammoth this year?
Old 03-26-2011, 12:44 AM
CALIH2O's Avatar
APPROX 8 FT OF SNOW THIS WEEK MULTIPLE STORMS CAME THROUGH SINCE SUNDAY. ITS BEEN FUN THOUGH. COIL SPRING CHANGEOVER IS COMPLETE GOODBYE AIR SUSPENSION. "YOHOO" WILL POST PICTURES WHEN WE GET BACK TO SOUTHERN CALI. THANKS FOR ALL YOUR HELP GUY'S THIS FORUM IS A GREAT TOOL FOR THE HUMMER NATION.
HAPPY TRAILS,
CALIH2O
