Old 04-04-2011, 09:11 PM
Dug Dug is offline
Dug is off the scale
Default Long time no see! Need help on tranny
Hey the H2 has around 200k on it now and its pretty well beat to a pulp. Anyways last week the transmission lost 1st and overdrive. On top of this problem the key wont shut off.
After searching here I found someone that had a similar problem as me. Does anyone know if this keyswitch problem makes the transmission not work? Thank you for any hints or ideas. I want to do some diagnostics before I pull the tranny out thats for sure. Thank you ,doug
Old 04-05-2011, 01:12 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Long time no see! Need help on tranny
The transmission will go into limp mode if it loses its ign 1 feed which is supplied by the ignition switch. Transmission will only have 2nd and 4th gear in limp mode.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-05-2011, 01:33 PM
Dug Dug is offline
Thank you HUMTECH ! Found some info on it also and ready to go finger this out and fix.
Old 04-17-2011, 03:44 PM
Dug Dug is offline
Ignition 0 was blown. Tranny still in limp mode . I'm still searching for ideas . Thank you
Old 04-17-2011, 04:30 PM
Dug Dug is offline
Put scan tool on it and said it had some trans issues. No ****. Cleared codes and trans shifts great . All fixed for now.
