Old 04-09-2011, 03:43 AM
mogie mogie is offline
mogie is on a distinguished road
Default p0200 error code
Hi all,
Just bought a hummer 2003 h2 off auction. I had the key stuck in ignition issue. Fixed it by cleaning the solenoid. Then it would stay in 3rd gear according to the instrument panel no matter where I put the shifter. I realized it must be disconnected from the tranny. I crawled under the hummer and reconnected the shifter. I need the clip that holds that in place by the way if anyone has a part number. So now I can get it into park.
I put in a new battery and attempted to start it. I got p0200. I know it has something to do with injectors. It tries to start and dies almost right away. I also got some codes relating to MAF and air sensors but I reset the codes, tightened the air intake (was loose) and am still getting p0200.
Where should I begin? thanks!
Old 04-10-2011, 10:44 PM
Default Re: p0200 error code
Originally Posted by mogie
Hi all,
alright, after replacing the map sensor (was pretty destroyed AND unplugged) noticed quite a few hoses unplugged. see pics. I don't know where they would go. The question is, if they're unplugged like that, would that cause the car not to start? I tested the injectors and they are getting power except one, which I fixed (loose cable). So now the only thing left to figure out is where these hoses go.....anyone??
http://i1202.photobucket.com/albums/...i/DSC03585.jpg
http://i1202.photobucket.com/albums/...DSC03584-1.jpg
