Old 05-11-2011, 11:13 PM
Humdingah Humdingah is offline
Humdingah is an unknown quantity at this point
Default Body Fastener Part Numbers
I was wondering if anyone knew the GM part numbers for the following body fasteners (I'm looking to get replacements/extras and can find fasteners in bulk that I can cross-reference with a GM part number):
The Phillips-head screws that hold corner cab marker lights on.
The Torx-head screws used to hold the fender flares to the hood/rear fender.
The metal clips that the above Torx-head screws go into that 'clip' onto the hood/fenders.
And one other odd request...on the front seats on the outside tracks there is a funky plastic 'cap' that has a clip that secures it to the seat track rail.
I've looked on GM Parts Direct at the illustrated views for cab lights, fender flares and seats and they don't show or list any of these items.
Thanks in advance,
Dan
Old 05-12-2011, 07:18 AM
Road Warrior H2's Avatar
Road Warrior H2 Road Warrior H2 is offline
Road Warrior H2 is on a distinguished road
Default Re: Body Fastener Part Numbers
Not show on the parts list I have either, Only the Lamp Assembly and the bulb
Front Detail view shows the following that I have
Item 2 is Upper Flare Retainer - 11561878
Item 4 is Lower Flare Retainer - 11588883
It does not show if they are Torx head screws or not.
Number 4 looks like one of those push clips ??
Only view I have shows the front and rear outside covers and side cover so assume the clip comes with it or is a part of it as I have not removed mine -
Front Adjuster outer Cover - 12473318
Rear Adjuster Outer Cover - 88935562
Side Cover - 88941540
Thanks in advance,
Dan
Not sure if that helps you or not but it was all my list shows
Old 05-12-2011, 02:23 PM
Road Warrior,
Where did you manage to find these? Thanks man!
Old 05-23-2011, 05:32 PM
Road Warrior,
I was lucky enough to get a copy of H2 Parts list from a member in the CHC Forum that I am also in and have enjoyed both places for information and all the things we all do to personalize our Hummers
