Old 05-16-2011, 01:45 AM
draconianruler draconianruler is offline
draconianruler is on a distinguished road
Default H2 stock rims with 37"
Will the 2009 20" stock rims work with 37x12.5 or 37x13.5 tires? Is it just better to get aftermarket rims instead?
Old 05-16-2011, 03:10 AM
Bimmer9938's Avatar
Default Re: H2 stock rims with 37"
If you are just cranking torsions, stock wheels are better cause of the high offset.
Old 05-16-2011, 05:22 AM
Just got the Hummer so sorry if its a dumb question but why do I crank the torsion bars? Is it for alignment? Also, I saw the stock rims are only 8.5 inches wide. Will this be an issue for the tires?
Old 05-16-2011, 05:26 AM
Bimmer9938's Avatar
Crank them to level (aka: raise the front). I'd go with the BFG cause it's a 12.50 which will seat better on your wheel.
