Old 05-25-2011, 09:51 PM
shawnwilkins's Avatar
shawnwilkins shawnwilkins is offline
shawnwilkins is on a distinguished road
Default Purchased replacement springs - advice on GM doing the work
I finally got a set of replacement springs for my H2 and need to get them on in place of the airbags as they leak almost 24/7 now.
I would like to keep the compressor in place and need to know the following:
1. Will GM do the work since I did not buy the parts from them
2. What should it cost
3. How do I keep the compressor from coming on once I have the springs in
4. Where do I pull the fuse or unit that controls the supsension warning on the dash
Thanks,
Shawn
Old 05-26-2011, 06:57 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Default Re: Purchased replacement springs - advice on GM doing the work
Way to go man. Here is the link that was posted sometime ago about the Service Air Suspension thing and the fuse:
http://www.elcovaforums.com/forums/s...pe nsion+fuse
Besides that, I would really try to see if someone else could do the springs besides GM, but it is up to you. 4x4 places have usually worked with this setup before, so they should be able to do the swap pretty quick; though I do understand not wanting anyone to touch the Hummer that doesn't know jack about Hummers, (been there, done that before). Just feel bad for the raping that the dealership will give you for the servicing, that's all.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 05-26-2011, 12:47 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
I'd like to know the answer to this question as well
I decided to keep the compressor after the spring swap but hear it come on every now and then.
Old 05-26-2011, 05:16 PM
Thanks for the information and I am going to call around to see who will do the work before just dropping it off at the GM dealer.
I will let you know what happens.
Thanks again!
Old 05-28-2011, 01:43 AM
H2Much's Avatar
On the compressor, best thing to do is just unplug it. Just have to pull the harness connector from it that is giving it power and it shouldn't turn back on.
