Old 06-16-2011, 03:01 AM
Bimmer9938's Avatar
Default H2 SKID PLATE & UNDER CARIAGE PROTECTOR, EASILY MODIFIED TO FIT OTHER GM IFS FS TRUCK
Just like the title says, I have an aluminum H2 front skid plate, I have seen one on a FS Chevy IFS truck before, no idea if it bolts right up, I assume the front dose, not sure if the rear had brackets made (looked pretty cool the truck had OEM H2 wheels too). Has two very small notches on side to fit IFS with lift kit. $100 pick up only.
OEM steel under carriage, needs a date with a powder coater, but saveable. Again I'm sure you can fab brackets and use on other GM trucks. $40. pick up only.
