06-16-2011, 04:21 PM
New owner with a problem
Hello all!
New owner of a 2005 SUV. Couldn't be more happy. I've always wanted one!
Now of course, Murphy's law has kicked in already. It didn't have this issue when I test drove it but now it's reared its head. I have a strange sqweak sometimes while driving. Never happens when I'm parked, only when moving. Its an intermittent noise but it stays constant. The noise level does not change with speed. At first I thought belts. The AC belt had visible cracking so I replaced both belts. Still have the noise. When I hear the noise, I'll give the steering wheel a little input and sometimes that will make it go away for a short time. Then it comes back. Any ideas?
I've searched this site with common words to my problem but haven't had much luck finding out what I should do next. Any help would be great. I'm not gonna let this stupid noise ruin my dream vehicle.
Thanks for anything! Happy to finally be in the club!
06-16-2011, 08:07 PM
Re: New owner with a problem
sorry i don't have an exact answer for you but i have a very constant squeak coming from the inside and i'm almost positive its a loose bolt in the dash... but im not gonna spend hours tearing through my dash looking for it. loose bolts are a very common source of squeaks. but from what you are describing it sounds as if its coming from under the hood?
oh and welcome to the forum! anything you need can usually be found on here
06-16-2011, 08:58 PM
It definitely sounds like it's coming from the engine bay. At first I thought wheel bearing but there isn't any grinding noise when I hear it. I wish it was obvious which place it is coming from. Could it be that a pulley is catching and the belt is sliding across it causing the noise? Is there a history of any of the pulley system failing like that?
06-22-2011, 04:46 PM
So I've ruled out the issue being in the engine area. I'm pretty sure its the passenger side wheel bearing/hub assembly. I'm starting to search for a good price on the part, but I'd like to know if anyone has performed this service on their own. Is it difficult? With basic tools am I going to have a major headache? Any pointers or tips to help take this on?
Thanks!
06-22-2011, 04:56 PM
Thanks!
wow sorry i didnt mention that before. before i had my hubs replaced(15k ago) they would squeal obnoxiously at low speeds and especially on accelerations. thats probably your problem. how many miles do you have?
06-22-2011, 11:32 PM
I bought it with just shy of 100k an now i'm about 101k.
06-23-2011, 01:48 AM
It could be the wind deflector for the sunroof. They have been known to squeak and it drove me crazy finally trying to pin it down. Open the sun roof and take hold of the deflector and see if it stops. Then there's the windshield trim pieces, that can rattle, buzz, and squeak if not firmly in place with an adhesive.
06-23-2011, 06:31 AM
I know thats not it. It has to be that bearing/hub assembly. I'm just curious how difficult a job its gonna be.
06-23-2011, 01:35 PM
Welcome
I just replaced my wheel bearing on both sides. Its not that hard to do, I took my sweet a$$ time and was through in 3 hours. The entire hub unbolts from the back as an assembly. I used Timken hubs.
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
06-25-2011, 04:24 AM
It could also be brake squeal. They may not be worn out, but sometimes it gets dry and dusty between the pad and the caliper if they weren't lubed well with the proper lube, and can squeal just going down the road. You could pull the wheel off and hose the caliper down really well with a can of brake cleaner and see if it stops. If it does, then I would just pull the caliper off and clean the back of the pads and relube them where they contact the caliper piston and put it back together. Just make sure you use actual disc brake lube. Most parts stores have little single use packets of them on the counter for a buck or so. Like little ketchup packets.
Mirror caps - black bedliner
06-26-2011, 02:25 AM
Shocking that a retard has a problem, Who the H ell buys a used hummer when the new ones brake down and rust thru if you look at them too hard.
BTW I hope your hummer burns down and takes your house with it. But not wile your in it I wish you no harm.
06-26-2011, 03:24 AM
A troll who can't spell... wow!
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
06-26-2011, 06:59 AM
Don't you know that I don't really care about good grammar I'm just trying to piss Humvee owners off because they keep running into my wonderful 1988 festiva
06-26-2011, 01:51 PM
I never thought of that. I'll start there next. The only reason I have my doubts about that is because the noise is intermittent and no one thing will cause it to start. Actually i take that back. If i'm making a sharp left turn going slow then i hear it and its very pronounced. Almost like two metal pieces being rubber together. Plus i'm sure my tires don't help the issue ouy any. Previous owner slapped on some Nitto Mud Grapplers. Damn truck sounds like an airplane! I hate these tires! My next mod after figuring this out is a nice long wearing set of AT's.
