Old 07-13-2011, 01:07 PM
pitpal pitpal is offline
pitpal is on a distinguished road
Default rear dvd not working
Im having trouble playing a dvd through the screens located on the headrests of the front seats. The actual unit is under the rear seats and i cant turn the unit on. Ive looked over the manual but cant find any info on how it works?
Its an 05 H2 and ive owned it for only a few months and tried it over the week end for the first time. Im either missing something or its not working.
Thanks in advance
Old 07-15-2011, 09:24 AM
Default Re: rear dvd not working
anyone??
Old 07-15-2011, 11:18 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
you could try this
#07-08-44-016A: GM Accessories Headrest DVD System Display Monitor Inoperative (Install Cable Connector Clamps) - (Aug 28, 2007)
Subject:GM Accessories Headrest DVD System Display Monitor Inoperative (Install Cable Connector Clamps)
Models:2004-2007 Buick Rainier
2008 Buick Enclave
2003-2008 Cadillac Escalade Models
2005-2008 Cadillac CTS, SRX, STS
2006-2008 Cadillac DTS
2003-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer Models
2006-2008 Chevrolet Colorado
2007-2008 Chevrolet Equinox, HHR
2003-2008 GMC Envoy Models, Sierra, Yukon Models
2006-2008 GMC Canyon
2007-2008 GMC Acadia
2007-2008 Pontiac Torrent
2005-2008 HUMMER H2
2006-2008 HUMMER H3
2007-2008 Saturn OUTLOOK
2005-2008 Saab 9-7X
This bulletin is being revised to update the models affected list. Please discard Corporate Bulletin Number 07-08-44-016 (Section 08 -- Body & Accessories).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2007042&from=sm#ss1-2007042">Condition
Some customers may comment on an inoperative display monitor or monitors in the GM Accessories Headrest DVD System.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2007042&from=sm#ss2-2007042">Cause
This condition may be caused by a loose connection at the display monitor cable connectors. These connectors are located at the lower rear part of both front seats. Two cables are routed to the display monitor in each seat.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2007042&from=sm#ss3-2007042">Correction
Do This
Don't Do This
Install display monitor cable connector clamps.
Do Not replace the DVD system display monitor.
Important: A number of headrest monitors have been replaced under warranty and in many cases, no trouble was found by the supplier when these units were analyzed. Therefore, technicians should be checking for loose connections and installing cable connector clamps to ensure a positive and robust connection.
Technicians are to install a video cable connector clamp on each cable connector located under each front seat. A total of four cable connector clamps, P/N 19159659, are required for each vehicle.
The illustration above shows a pair of display monitor cable connectors without the cable clamps installed.
The illustration above shows the display monitor cable connectors with the cable connector clamps. The lower cable connector clamp is installed but not locked together. The upper cable connector clamp is closed and locked.
The cable connector clamps have now been added as a permanent component to all GM Accessories Headrest DVD Systems installation kits.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2007042&from=sm#ss4-2007042">Parts Information
A total of four clamps are required for each vehicle.
Part Number
Description
Qty
19159659
Clamp, DVD Cable Connector
4
1998 Chev Z71
2007 Chev Trailblazer SS
Old 07-18-2011, 03:50 AM
Just before i try anything else, can somebody tell me were the power on button is, on the unit under the seat? I cant work it from the unit in the dash or from the rear screens either? Just want to make sure its not human error before i go any further. Sorry for my ignorance but something is missing on my H2, or am i missing something???
Old 07-18-2011, 12:31 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Also check the fuses, could be as simple as that too.
Old 07-18-2011, 01:48 PM
guruerror's Avatar
Are you certain that it's a stock system?
CNTRY
DTOM
Old 07-18-2011, 02:03 PM
I m pretty sure its a stock system but not certain as i havent looked closely at another one. I presume you load the disks for the rear dvd in the unit under the rear seats??
