Old 07-17-2011, 07:42 PM
ogden ogden is offline
ogden is on a distinguished road
Default Dealer changed fluid 2 quarts overfilled ?
I recently had my H3 transmission service by my local dealer. The transmission started to shift a little different, engine would rev high before shifting. I had the vehicle in yesterday and the service tech said he found a misfire on (1) but the transmission had no codes. Today I thought I would check the transmission fluid !! The stick was not in the transmission hole at the bottom ? Seems the bracket was broke up top on the engine and the stick was dangling outside the transmission. I relocated the stick in place and found they overfilled it to the top of the stick ???
Any suggestions on how bad the transmission is damaged.
Ogden
Old 07-23-2011, 08:11 PM
Default Re: Dealer changed fluid 2 quarts overfilled ?
Did you go back and speak with the service manager and have it fixed?
Old 07-23-2011, 10:59 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
You had the engine running when checking the fluid right?
1998 Chev Z71
2007 Chev Trailblazer SS
