Old 07-20-2011, 01:47 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
Default Lift Height Measurements
I also own a sports car, and on one of our forums, they had a thread where people posted the actual drop of their car, measured from the center of the hub to fender. So it got me thinking, why don't we do the same here to measure our lifts? There are a lot of people putting lifts on lately, and it might be a good resource for everyone to have in one post.
So, when you get a chance, please measure the distance from the center of your hub to the bottom of your fender, front and rear. Even if you've only put on a leveling kit, measure front and rear. DO NOT measure from the ground. And just as importantly, post your lift kit and tire/wheel size.
Sadly, I'm at work thinking of this, so I can't post what I have just yet. I will when I get home.
P.S. If this has already been done, my apologies, but I'm assuming we could use an updated one.
