Old 07-28-2011, 02:58 AM
Joe Joe is offline
Joe is off the scale
Default Service Air Suspension
Is there a common cause for the Service Air Suspension popping up on the DIC? Appears there are no related codes to pull to isolate the problem.
Bags seem to be inflated and not leaking as the suspension seems fine. The Ride Height doesn't work though for sure. Just blinks and does nothing. Doesn't even seem to run the compressor. Compressor does from the rear switch but not sure if its actually doing anything. Been a bit to hot in the east these last couple weekends to climb under the truck and have a looksy so I'll admit to not having done full due diligence on this. Just trying to gain a heads up on the common problems especially if its not a crack/leak in the bags themselves.
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
