Old 02-21-2005, 04:22 PM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2900.2604" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1587795
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM>
<HR>
</FORM>
<H1>Info - Automatic Transmission Shift, Engine Driveability Concerns or Service
Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled
Aftermarket, Reusable Air Filter #04-07-30-013A - (Jan 25, 2005)</H1>Automatic
Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES)
Light On as a Result of the Use of an Excessively/ Over- Oiled
2005 and Prior GM Cars and Light Duty Trucks</P>
2005 and Prior Saturn Models</P>
2003-2005 HUMMER H2</P>
This bulletin is being revised to add additional model years and to clarify
warranty coverage. Please discard Corporate Bulletin Number 04-07-30-013
(Section 07 -- Transmission/Transaxle).</P>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
DO THIS</P></TH>
DON'T DO THIS</P></TH></TR>
<TR>
<TD vAlign=center align=middle>
First, Inspect the vehicle for a reusable aftermarket
excessivelyover- oiled air filter</P></TD>
DO NOT repair MAF sensors under warranty if concerns result
from the use of an excessively/over-oiled aftermarket, reusable
air filter.</P></TD></TR></TBODY></TABLE><A name=ss1-1587795><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1587795&pubid=293&evc=sm#ss1-1587795">
<H5>The use of an excessively/over-oiled aftermarket, reusable
air filter may result in:</A></H5>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top><FONT size=4>•</FONT></TD>
<TD vAlign=top>Service Engine Soon (SES) Light On
</TD></TR></TBODY></TABLE></DIV>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Transmission shift concerns, slipping and damaged
clutch(es) or band(s) </TD></TR></TBODY></TABLE></DIV>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Engine driveability concerns, poor acceleration from a
stop, limited engine RPM range </TD></TR></TBODY></TABLE></DIV>
The oil that is used on these air filter elements may be transferred onto the
Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the
Grams per Second (GPS) signal from the MAF may be low and any or all of the
concerns listed above may occur. </P>
When servicing a vehicle with any of these concerns, be sure to check for the
presence of an aftermarket reusable, excessively/over- oiled air
filter. The MAF, GPS reading should be compared to a like vehicle with an OEM
air box and filter under the same driving conditions to verify the concern.</P>
The use of an aftermarket reusable air filter DOES NOT void the vehicle's
warranty.
</P>
If an aftermarket reusable air filter is used, technicians should inspect
the MAF sensor element and the air induction hose for contamination of oil prior
to making warranty repairs.
</P>
Transmission or engine driveability concerns (related to the MAF sensor
being contaminated with oil)
that are the result of the use of an
aftermarket reusable, excessively/over-oiled air filter are not
considered to be warrantable repair items.</P>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Klaus's Avatar
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<TBODY>
<TR>
DO THIS</P></TH>
<TR>
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1587795&amp;pubid=293&amp;evc= sm#ss1-1587795">
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
warranty.
</P>
</P>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved.
</P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 02-21-2005, 11:06 PM
Klaus what are We to do? Check and make sure they are not over oiled? Perf. shop put mine on infact it was the company that had been making proflash programer. I bought his air sys., throttle body spacer, and programer. I know that anyone that has used K and N should know that after they clean and reoil that You spray oil to just barely change color from white to I'll call it pink or very light red or at least that is what I have always done. Seriously what is Your thinking on this so if i need to do something different I want to know right away and do it. I know I have been in for 1 oil change and service and I see the same ser. manager every time or if i call I talk to Him. He has never mentioned anything. Please let Me know what you are think or are hearing should be done. Go back to stock?
Thank You for bringing this up.
TAZ (Rick)
