Old 09-08-2011, 06:02 PM
billyb billyb is offline
billyb is on a distinguished road
Default big leak !!!!!
Anyone have ideas to solve a problem with a leaking area over the passenger side of my H3....or has anyone had a similar problem ? With the amount of rainfall in the Northeast, I find a puddle on the passenger side floor, and noticed a drip underneath the glove compartment. The sun-roof seal looks good and I also noticed that there is a drain hole that may be clogged...any one have an answer...........Thanx BB
Old 09-08-2011, 11:22 PM
HummerJim's Avatar
Default Re: big leak !!!!!
It's normally the sunroof drains that get cloggged - just run a wire down them then wash them out with water. If it's not that then it's the front window seals at the vertical plastic strips. I had both on my H3 after water on the carpet fixed under warranty when I had mine.
Old 09-09-2011, 03:14 AM
jphh20 jphh20 is offline
jphh20 is on a distinguished road
Mine has been leaking all summer here in CT... Unfortunately it started when the windshield was replaced and they had to remove my amber light bar. The windshield company and ex-Hummer dealer have worked on it 11 times and it still leaks. Mine is over the driver side and runs down the inside of the windshield. Tomorrow they might pull the head liner out which I am uncomfortable with to see where the water is coming in. My sunroof drains are clear...
