Old 09-21-2011, 12:52 AM
HMH2SUT HMH2SUT is offline
HMH2SUT is on a distinguished road
Default p0332 fixed now showing p0327
Ok I had a p0332 code I replaced both knock sensors the wiring harness and the intake gasket. Everything was fine for about 80 miles then the engine light came on again showing p0327... everything was torqued to spec and the harness isn't routed next to a coil or plug wire... any thoughts? I bought the harness and intake gasket from the dealer, but got the knock sensors from cheapozone.... anyone had problems with autozone sensors throwing false codes??
Any input is appreciated. Thanks
2005 SUT Used and Abused, you name Ive broke it!
