Old 09-22-2011, 03:22 PM
beastie beastie is offline
beastie is on a distinguished road
Default Inside rear view Mirror
New to the forum and Hummer, both of which are pretty cool.
I have searched and searched.....
Can someone supply me with a wiring diagram for the inside rear view mirror. My mirror has the "comp" and "temp" buttons only, the connector on the back is a single row connector. Everything I have seen is a double row connector.
OOOOOOO Mine
OOOOOOO
OOOOOOO Others
Anyway, its not working and well I would like it to.
Thank you!!
2005 H2
Old 09-22-2011, 09:55 PM
Easy Ed Easy Ed is offline
Default Re: Inside rear view Mirror
Sorry I cannot help ya cause my 2003 has the double row one and the 2003 service manual only shows the same double row.
Hope twr (Tracy) can help ya out if he happens to check your post, he has a little "more access" to helpful info/data.
Good luck, Ed
Old 09-23-2011, 02:52 AM
twr's Avatar
twr twr is offline
Hi i only have access to 2008 pics and wiring at this time sorry. What does not work temp comp?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-23-2011, 03:19 AM
twr's Avatar
twr twr is offline
This is out of the 2005 owners manual on setup, i tried to make it bigger you have to copy it and edit it. Its the best i can do
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-23-2011, 03:33 PM
Thank you TWR and EasyEd
Neither comp nor temp work, doubt the auto dimming is working either. I'm going to test the power to the mirror tonight.
I pulled the wires down from under the headliner last night and they have been cut and spliced, so I'm not really sure what pins are what and if its connected correctly.
I have access to an 04 and a 06 so I'll go check those out to see if similar.
Thanks Again.
Old 09-23-2011, 03:47 PM
I do have access to an 2005 service manual, where did you find the inside rear view mirror in the manual?
Old 09-23-2011, 03:53 PM
Found it!!
Old 09-23-2011, 08:11 PM
Best of luck now that you have the service manual to help ya out, I use mine quite a bit
Hope all goes well in finding the problem and fixing it.
Ed
Originally Posted by beastie
Found it!!
