Old 09-22-2011, 04:54 PM
MrIgor MrIgor is offline
MrIgor is on a distinguished road
Default bi-xenon install help
I bought a kit on ebay bi-xenon h13 9008 kit. It hooks up for easy with no problems, but high beams do not work (they glow but the bulb dont move in). The bulbs are have to move in for high beam, and say out for low beam.
You use on ONE headlight plug as a trigger, and the other is not used. If I plug a bulb into the 2nd plug the lights go into high beam mode right away and do not snap out.
You have 3 wires that are used as trigger, maybe they need to be different polarities, or in a different order.
Did anyone install bi-xenon kit on a H3 hummer that can help me solve this problem.
Old 09-23-2011, 05:39 AM
twr's Avatar
twr twr is offline
Default Re: bi-xenon install help
Hi do you have a link to kit you bought so i can see the relay harness that came with the kit? It sounds like their is a problem in the relay harness or the 2 small plugs with 2 wires going to the bulbs.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 01-26-2012, 07:36 PM
Beast05 Beast05 is offline
Beast05 is on a distinguished road
Hello TWR,
I see you installed the Starr Hid projector headlights on your H2. Can you tell me or direct me to directions for the install. I would like to buy some for my Hummer but want to know what I am in for before the purchase.
Thanks in advance.
Old 02-03-2012, 03:13 AM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
It's a polarity issue. I believe you need to swap the blue and the white wire on the harness. You'll need a super small flat head to change them. Do a quick search on Google.
