Old 09-25-2011, 02:54 AM
dna dna is offline
dna is off the scale
Default ac blowing warm
Haven't used my ac for a very very long time (maybe a year +). Just turned it on and all I get is warm air. Actually is slightly colder if I only put temp down to 15 and do not hit the ac button (warms up once I hit the ac button).
So where do I start. Confirmed the belt is good and the compressor is turning with the belt.
Old 10-02-2011, 03:29 PM
finbox finbox is offline
finbox is an unknown quantity at this point
Default Re: ac blowing warm
charge it up and see if it blows cold
Old 10-02-2011, 07:47 PM
Indy's Avatar
Indy Indy is offline
Don't forget that when you see the AC symbol, it has a small line through it....means it is turned off....when the symbol is not showing, then the AC is on....I always have found this strange...why not put in an AC symbol for ON and no Symbol for OFF instead of a crossed out AC symbol, which is soooo tiny that nobody can see it.
Old 10-03-2011, 02:18 PM
H2005's Avatar
H2005 H2005 is offline
H2005 is an unknown quantity at this point
I think the ac with the slash through it was only on the 03 model years
Old 10-03-2011, 09:57 PM
guruerror's Avatar
Yeah...my snowflake does not have a slash through it...2005.
CNTRY
DTOM
Old 10-08-2011, 10:47 PM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Thumbs up Re: ac blowing warm
Sounds to me like your compressor has gone out. Either it has gone out or it has blown a seal. Any vehicle AC place should be able to assess this and fix the seal if that is what it is. If not, you're looking at about $1k for a new compressor.
I have had both happen, so I am familiar with the symptoms. 1st time, it was the compressor that had gone out. Second time, it happened right after winter the first time I went to turn on my AC, just started blowing warm. This time it was the seal. Apparenlty, cold to warm weather can mess with the seal and weather it to where it pops off. Hopefully that is all it is- good luck.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 10-09-2011, 12:46 PM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
the main cause for a bad compressor seal is not running thee A/C in the winter. The seal takes a set and then leaks. Try to run your A/C for a few minutes every week during the winter
2004 Black H2
