Old 10-28-2011, 02:17 AM
Rob 4092xx Rob 4092xx is offline
Rob 4092xx is on a distinguished road
Default Can someone look under there transmission and help me??
I have a 2009 H3.
I was underneath it today and noticed there are two holes on the underside of the transmission.
I know the larger hole (about 1 1/4" round) takes a thin aluminum plug that pushes in to cover it.
My question is this....does any type of plug go into the smaller hole (about 1/3" round) or is this one open all the time?
Thanks!!!!
Old 10-28-2011, 03:05 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Default Re: Can someone look under there transmission and help me??
I don't have a 2009 but my 2008 Alpha transmission only has a drain plug. Can't believe any transmission is supposed to have an open hole. What do you think would happen to the transmission fluid if this was the case? Are you sure you are looking at the transmission?
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 10-28-2011, 03:10 PM
I think it is the transmission. There are two holes in it. One has a very thin metal plug that just pushes into the larger hole. The plug does not fit tight at all. There is a smaller hole next to it. There isn't any plug in it. I am trying to figure out if the smaller hole needs a plug.
I assume it is the transmission I am talking about. It is the big silver colored case under the car.
Old 10-29-2011, 12:22 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I think your talking about #97
(1)Torque Converter Assembly ?  Size Model Dependent(2)Pump to Case Bolt(3)Pump to Case Bolt O-Ring(4)Oil Pump Assembly(5)A/T Fluid Pump Seal ? Pump to Case(6)Pump Cover to Case Gasket(7)Case Bushing(9)Transmission Vent Assembly(11)Case Servo Plug(12)Servo Return Spring(13)2nd Apply Piston Pin(14)Retainer Ring ? 2nd Apply Piston(15)Servo Cushion Spring Retainer(16)Servo Cushion Spring ? Outer(17)2nd Apply Piston(18)Oil Seal Ring ? 2nd Apply Piston ? Outer(19)Oil Seal Ring ? 2nd Apply Piston ? Inner(20)Servo Piston Housing ? Inner(21)O-Ring Seal(22)Servo Apply Pin Spring(23)Servo Apply Pin Washer(24)Retainer Ring ? Apply Pin(25)4th Apply Piston(26)Oil Seal Ring ? 4th Apply Piston ? Outer(27)O-Ring Seal ? 2?4 Servo Cover(28)2-4 Servo Cover(29)Servo Cover Retaining Ring(30)Case Extension to Case Seal(31)Case Extension ? Model Dependent(32)Case Extension to Case Bolt(33)Case Extension Bushing(34)Case Extension Oil Seal Assembly ? Model Dependent(34)Case Extension Oil Seal Assembly ? Model Dependent(35)Speed Sensor Retaining Bolt(36)Vehicle Speed Sensor (VSS)(37)O-Ring Seal ? VSS to Case Extension(71)Filter Seal(72)Transmission Oil Filter Assembly ? Model Dependent(73)Transmission Oil Pan Gasket(74)Chip Collector Magnet(75)Transmission Oil Pan ? Model Dependent(76)Transmission Oil Pan Screw(94)Converter Housing to Case Bolt(95)Oil Cooler Quick Connector(96)Oil Cooler Quick Connect Clip(97)Converter Housing Access Hole Plug ? Model Dependent(98)Converter Bolt Inspection Plate ? Model Dependent(99)Cup D4 Orifice Plug(102)Converter Housing ? Model Dependent(103)Main Section Case ? Model Dependent(105)Servo Cushion Spring ? Inner ? Model Dependent? 2011 General M
1998 Chev Z71
2007 Chev Trailblazer SS
Old 10-29-2011, 12:26 AM
WOW! That is it!
I really appreciate you taking the time to figure this out for me!
The info made it easy for me to call my dealer and order that part. They were amazed I had teh exact description and number for the plug!
Thanks again!!!!!
Old 10-29-2011, 02:06 AM
HUMTECH's Avatar
Np
1998 Chev Z71
