Old 11-03-2011, 06:43 PM
emillika emillika is offline
emillika is off the scale
Default Driver seat adjustment issue
My wife's 2004 H2 is having an issue with the driver seat adjustability. The seat moves up/down tilts forward/back thru the complete range of expected motion. However, it will only move forward/reverse about an inch or so in each direction.
-seat heaters work fine
-passenger seat works fine in all regards
-checked for any obvious obstructions near the seat track
-blew compressed air along the track
I have searched here and online but no luck yet. Removed several fuses to see if the seat control module would "release" it's memory and also disconnected the seat control module under the driver seat for 10 minutes but no luck so far.
Any idea's on what else I can check?
Thanks.
Old 07-05-2012, 08:36 PM
wallyyachts's Avatar
wallyyachts wallyyachts is offline
wallyyachts is on a distinguished road
Default Re: Driver seat adjustment issue
Anyone have advise on this? my 06 H2 is doing the same thing.Thx!
Old 07-05-2012, 08:49 PM
VegasMike VegasMike is offline
VegasMike is on a distinguished road
Can you switch the modules from the passenger seat to the drivers seat and see if that resolves it? That will tell you if it's the module or not.
EDIT: If that fixes it, it looks as if the module may be reprogrammable by a GM dealer.
Old 07-06-2012, 04:44 AM
pdxrealtor's Avatar
You have two Hummers both doing this?? Talk about some weird luck!
I don't have any suggestions, sorry. Let us know what it turns out to be.
Good Luck!
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 07-06-2012, 12:22 PM
Tried swaping them. the Tech 2 says horizontal seat sensor. Seems that is located in the motor. Its a $500 gamble by changing the motor. Someone had a comment a while ago that is was a programing issue with a GM tech bulletin.
My fear is that my local dealer(not too bright) will not know. I called and service really had no clue. If I go the dealer route, I have to stress to them that rape is against the law.
