11-06-2011, 07:31 PM
My Hummer H2 2003 Black Out
18" XD796 XD SERIES REVOLVER on Nitto 37" Terra Grapplers. The fronts tires rub alittle when making a sharp turn. Any suggestions with shocks and a leveling kit? I used some 3m vinyl tape on the mirrors and door handle to cover up the chrome.
I sprayed the top roof rack rails with Rustoleum bedliner spraypaint.
My next project is spraying the bedliner on the front grill. Anybody have any tips before I do it?
11-06-2011, 10:01 PM
Re: My Hummer H2 2003 Black Out
The 3M Vinyl on the mirror and door handles look good! Can you provide a part number for the vinyl you used, as well as, some tips for how you laid it on the side mirrors? I need to do mine and was trying to come up with a way to do it without having to buy new mirrors. Nice job!
Reggie
11-07-2011, 05:17 AM
Great job! Love it!
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
11-07-2011, 02:10 PM
Remove the chrome caps off of the mirror. There are clips and double sided tape that held the mirrors on, just pry them off gently. When you apply the 3m vinyl use a blow dryer or heat gun. The first one I let the gun get to close to the tape and I poked a hole in the tape and had to start over with a new piece. I only bought a $20.00 piece and it covered both mirrors, the door handles and the back chrome over the liecnse plate. You have to keep working the 3M with the gun, folding it over the corners first, If you get a wrinkle just pull the tape up and apply some heat and then lay it back down on the mirror. I didnt remove the door handles, I just laided a piece on it and put the seam in the back of the handle so you cant see it. There are some bumps when you grab the handle in the back only because I rushed it and ran out of the tape. I'm going to do the steering wheel with the carbon fiber 3M. I did a test run wuth the flat black tape and it came out good also. I;m only doing it because for some unknown reason , parts of the steering wheel are GOLD???
11-07-2011, 02:28 PM
Thanks Deathshead67!
11-07-2011, 09:37 PM
Reggie: Check out this thread http://www.elcovaforums.com/forums/s...hlight=mirrors Scarsman gives a good explanation about getting those caps off.
CNTRY
DTOM
11-08-2011, 04:30 PM
looks good man! take a look at a product called "Plasti Dip" for your grille. It has a true flat black look to it and the best part is that it peels off if you dont like it. I know....sounds weird, but visit your local lowes and pick up a couple of cans.
Sold!!! 2009 H2 SUV Graystone Metallic. Next stop, 2006 H1 Alpha Hard Top
11-09-2011, 07:03 PM
Thanks!!
Hybrid Mode
