Old 12-21-2011, 03:49 AM
Wibs Wibs is offline
Wibs is on a distinguished road
Default How to remove the chrome plated plastic air cleaner covers
Hi, does anyone know how to safely remove the chrome plastic cover without damaging the paint, I think the chrome plastic cover is held by an adhesive tape.
Thank you.
Old 12-21-2011, 01:56 PM
2010_5thgen's Avatar
2010_5thgen 2010_5thgen is offline
2010_5thgen is on a distinguished road
Default Re: How to remove the chrome plated plastic air cleaner covers
those arent factory are they ? and if their held on by tape.....just use a razorblade if you can to get the tape separated from the glue then clean the glue off the paint.
2012 Porsche Panamera 4
Old 12-21-2011, 05:03 PM
guruerror's Avatar
If they are the actual caps they should just pull up...they are held in by about 4 clips (if memory serves).
CNTRY
DTOM
Old 01-01-2012, 07:16 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Yah, these things are overlays, so they are attached to the paint on the top with 4 strips of the double sided 3M tape. They are going to be a pain in the A** to get off, so your best bet is to pull off the actual part that the chrome overlay is stuck too, and then put some warm water in between the two with some dawn soap and let it soak. This should help to get them separated without damamging the paint.
Good luck, because that will suck and probably take some time to do...
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
