Old 12-25-2011, 08:13 PM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Default Transfer case overflowing
So While looking at something else under the truck I noticed my transfer case had had fluid leaking around it, upon checking the tightness of the plugs I found the fill plug completely loose, I pulled it out just for the hell of it and it was just gushing fluid out...
I did have someone replace the fluid, but I still don't see how it could get filled that high by itself.
Upon searching the forums I found a similar topic only it ended up with the cause of the problem being rooted to a lot of deep water fording, I have done no such thing in a quite a while, certainly not since I had the fluid changed.
The fluid is dark red in color.
Is it possible that the transmission could be leaking into the transfer case, I don't see many possibilites...
The truck seems to drive just fine..
