Old 01-10-2012, 07:22 PM
Wibs Wibs is offline
Wibs is on a distinguished road
Default Tire pressure monitoring system issue
Hi, according to the label on the door jam, the cold tire pressure for the 2008 H2 is 42 psi.
If your cold tire has a pressure of 42 psi then why do I get a warning saying that the tire pressure is low ?
After I inflated the tire to around 48 psi, the warning is still there....or do I need to inflate it even higher ?
Is there a reset button that you have to push after you inflate the tire ?
Any thoughts ?
