Old 01-27-2012, 05:07 AM
accely's Avatar
accely accely is offline
accely is on a distinguished road
Default Starter going bad?
Hey guys, I think my 05 H2 starter might be going bad...
Sometimes it clicks once and stops, just started doing it yesterday and it finally started after about 8-10 tries. Today it started fine when I went to the gym, but when I came out it took about 3 times to start, again just clicking once each time it failed.
Sounds like the starter? I just replaced the battery maybe 6 months ago so I can't believe it'd be that.
I looked on AutoPartsWarehouse website at replacement starters and they range from 120$ to almost $300... they all seem OEM so what's the big difference?
thanks!
edit -- found this here for 65$ seems legit... opinions? http://www.discountstarterandalterna...-12564110.aspx
Yellow 04' H2
Old 01-27-2012, 02:04 PM
HummerJim's Avatar
Default Re: Starter going bad?
I've had batteries go bad in a few months. When you turn on your key what does the voltage gauge on the dash read? If it's 11 or less, your battery is bad. I haven't heard of that many starters going bad on H2s, but I have heard many ignition switches in the steering column going bad. This was a pretty common problem, but I thought they fixed it with the '06s and on????
Old 01-27-2012, 07:35 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Next time it just clicks hit the starter with a hammer a few times while someone is holding key in the crank position, if it starts to crank your starter is bad.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-27-2012, 08:42 PM
accely's Avatar
well too late for anything, went to subway and it wouldn't start after I came out. It's in the shop now.. I'll let you know what it is.
Yellow 04' H2
Old 01-28-2012, 04:07 PM
accely's Avatar
Yep, it was the starter.
They mentioned my front end was pretty loose too, pitman, tie rod, idler, ball joints. Time to start looking at parts to buy I suppose.
Yellow 04' H2
