Old 02-05-2012, 04:02 AM
jsbihn jsbihn is offline
Moderator
Default removing the center shift console?
Is there a way to remove the center shift console on a 03 H2?
I need to take it out as much as possible to pull up the padding underneath and replace it
Thanks for any help
Old 02-05-2012, 04:15 AM
Easy Ed Easy Ed is offline
Default Re: removing the center shift console?
http://www.elcovaforums.com/forums/s...ead.php?t=6623
Old 02-05-2012, 01:30 PM
HummerJim's Avatar
Just don't forget the fastener of the front side of the gear shift. I had a heck of a time figuring out how to take it off until I saw there was an allen wrench type screw in the front, hidden against the center console with the shift lever full forward in Park.
Old 02-05-2012, 11:37 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Its a t-15 torx bit in the shifter handle
1998 Chev Z71
2007 Chev Trailblazer SS
Old 02-06-2012, 12:24 AM
Moderator
Thanks guys.
That will be my tomorrow project.
I need to order the mat and possibly the carpet since it smells wet still in my truck.
I need to pull up and out the carpet since I ripped the sponge that is known as the padding out.
I would have done that today but the time wasnt there after I worked on the Vette and then the biting gnats started getting to me since it was after 430p.
Ugh!
Anyways, The positive spin is I can do some wiring for my fire dept flashers and also pre-wire in an amp setup to give the stereo just a little bit more ooomph.
Thanks for the info!!
Old 02-10-2012, 05:56 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
fyi, if you lose or break any of those clips from the above link, which no matter how hard I tried not to, I lost one very time,,, you can get them at you local GM dealer for like 89 cents each...
Old 02-10-2012, 11:57 PM
Moderator
Thanks.
Yeah I am getting ready for the re-install this weekend.
The truck is dry, the carpet is clean, getting some new padding from the local carpet store and then I should have everything fine, plus I will have adding in a subwoofer
:-p
