Old 02-07-2012, 10:04 PM
jsbihn jsbihn is offline
Moderator
Default Can I hook my Android phone up to my stereo?
Hey all,
I have a '03 H2 with the Bose stereo system. It is a stock system right now (meaning no nav, just radio / cd setup). I am getting ready to install a subwoofer to the stock system, by use of a PAC C2AGM24 (this looks to be the correct model for my year). The install looks pretty simple, especially in comparison to other installs I have done.
The question is: "Can I some how hook my android phone (Samsung Infuse 4G) into the stereo to get it to play music from it through my stereo and also use my stereo as a speaker phone?"
I do have the OnStar button, though I dont know if it works or if it is activated since I bought the truck 2 weeks ago used.
Any comments?
Thanks!!
Old 02-08-2012, 01:35 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Default Re: Can I hook my Android phone up to my stereo?
Does your '03 have an auxiliary jack? I play my iPhone through that all the time. If it does all you would need is an auxiliary cable.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 02-08-2012, 03:49 AM
Moderator
I havent seen one
Where would it be if there is one?
Old 02-08-2012, 04:29 PM
tyler1bo's Avatar
It's just a hole like you'd stick a headphone cable into. It will play the music but it won't allow calls to run through the stereo.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 02-09-2012, 01:04 AM
Moderator
I assume that this is an easy jack to find?
ie: on the front of the headunit?
if so, i dont have one
So, I am wondering if there is any other ways?
Old 02-11-2012, 06:51 PM
Moderator
Anyone?
I dont have a headphone type jack on my stereo. I have H3 with a stock stereo, I just want to know how I can connect it to play music or maybe even have my phone through the stereo?
I do also have OnStar if that makes a difference.
Old 02-15-2012, 03:44 AM
[__--MUD--__]'s Avatar
there is an extra input module you can get to do it... try calling crutchfield. They'll get you going in the right direction.
Old 02-15-2012, 07:37 PM
Moderator
thanks
Old 02-18-2012, 05:09 PM
EuroHummer's Avatar
EuroHummer EuroHummer is offline
EuroHummer is on a distinguished road
http://www.icarkits.com/cars/HUMMER_...4/BlueSTAR2010
2003 H2, 408 CI, K1 Forged 4" stroke crank, K1 6.125" forged rods, Wiseco X-Series 0.30 forged pistons, Schneider cam, FAST 102mm LSXRT, precision flow injectors, Comp Pro Magnum rockers, SA Gear DR timing set, ARP main studs, 90mm ETC TB, Airaid MIT, MSD Coils/wires, Dynatech Headers/high flow cats, Magnaflow, Jessie James Black Widows 20x9, Nitto Dune Grapplers 37", Fabtech 6" lift, CK Performance XHD 4l70e and 4.56 Gears
