Old 03-05-2012, 11:01 PM
H2duramax H2duramax is offline
H2duramax is on a distinguished road
Default I think I am having some electrical issues
Ok so for the last couple days my 2008 h2 has been having some issues, the recycled air light flashes on and off while driving down the road and the flow from the a/c seems to surge as well. Today I have had a new problem with the factory stereo, my wife and I drove to an appointment downtown with no problems, but when we left the radio would not play. The unit had power and went through the motions but it was like there was no connection to the speakers. It tried am/fm, xm, cd, and the DVD player. No sound at all. Powered it on and off several times on the hour drive home and no change. I went out to the truck a little while after I got home and now it plays fine.
So what do y'all think? Anyone else had anything like these happen?
Old 03-06-2012, 02:20 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
Default Re: I think I am having some electrical issues
Could be the dealer doing voodoo on you. They probably just read your post about getting a free duramax from them...
Old 03-06-2012, 02:54 PM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
My guess might be that you have a bad ground connection someplace. Usually when electrical issues are present, they are either blown fuses due to some kind of short in the circut or a poor ground connection that disables things without any damage to the item itself. Check all your connections that involve the stereo and look for any looseness in either the connector or the wire itself. A ground wire could also be touching something hot as well. Best of luck.
Old 03-06-2012, 04:02 PM
twr's Avatar
twr twr is offline
Hi is their any aftermarket interfaces hooked to the radio, like for a ipod? If not the amp may be a problem and not have turned on.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 03-09-2012, 05:30 PM
Thanks for the replies. The situation has fixed itself for the time being. Hopefully there are no recurances. The radio is the factory nav unit, so there is nothing aftermarket that could have been causing the problem.
