Old 03-09-2012, 05:22 AM
cashville cashville is offline
cashville is on a distinguished road
Default How do you use sea foam?
I'm going to have to use sea foam, because I think I have my injectors clogged.
I would like to know how you guys usually do it, do you add a can through the vacuum line, or use a can in the gas tank, or both?
I was thinking of doing 1 in the gas tank, but now I've been reading, and I'm thinking of pouring one in the vacuum line also. What do you guys think?
Old 03-09-2012, 11:00 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: How do you use sea foam?
replied to your thread on the other forum....
Old 03-09-2012, 11:24 PM
guruerror's Avatar
I'd be interested in seeing LoJac963's response.
Personally I use it via the gas tank on both the truck and ATV.
CNTRY
DTOM
Old 03-10-2012, 02:56 AM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
you could also go with having the injector system cleaned by a professional where they remove the fuel pump fuse letting the rail pressure down. Then connecting pressurized cleaner kit thru the fuel rail. This injects the cleaner to the injectors immediantely.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 03-10-2012, 11:13 PM
LoJac963's Avatar
The basic way most people use it is through the upper intake manifold. Those are all the videos on youtube you'll see with the white smoke flowing from the tail pipes.
Disconnect the vaccum line (on my last LS2 it was at the rear of the intake mani) and have the engine running. Fill a cup with the Seafoam and slowly let the engine suck the seafoam into the upper manifold and into the combustion chambers. The goal is not to kill the engine but to keep it running. Once all the seafoam is in turn the engine off and let sit for 10-15 mins then start it back up-done.
In addition to the above you can also add Seafoam to the crankcase (oil) and the fuel to clean the fuel system. If you have adapters it can be added directly to the fuel rails for a more direct approach to the injectors.
Just my tid bits I know about doing it
Old 03-11-2012, 04:12 PM
Where's the vacuum line in an h2?
If anybody could post a picture so I don't screw up, that would be great!
Old 03-11-2012, 08:25 PM
tiny2012's Avatar
tiny2012 tiny2012 is offline
tiny2012 is on a distinguished road
you tube shows how to use it.....
Old 03-12-2012, 12:40 AM
LoJac963's Avatar
On my GTO with the LS2 you actually disconnected the vaccum brake booster line and used that. I haven't taken a look at the H2 to see but it should be in a similar location towards the rear of the intake manifold. If I get a chance to take a look I'll let you know if no one else finds it
