03-21-2012, 07:00 AM
Ordering 12 inch lift, what tire/wheel combo?
Just put down a deposit with my shop for a 12 inch bulletproof lift. I had my mind set on 40inch SS M-16s on 24x12 rockstars, figured if im going to spend the money jacking it 12 inches why not go bigger 44 Trxus sts on 20 bmf wheels? Truck will see some snow, sand, mud... will spend most of its time on the pavement. Any thoughts? Other recommended wheel tire combos?
03-21-2012, 07:23 PM
Re: Ordering 12 inch lift, what tire/wheel combo?
If you're going to stay with a 20" Wheel, the tire that would look amazing IMO would be the Pit Bull Rocker 44x19.50 R20. I also love Iroks, but the Rockers will give you some width to the stance. Rigs with huge lifts and skinny tires just don't look good IMO.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
03-21-2012, 07:48 PM
CNTRY
DTOM
03-21-2012, 10:29 PM
you really know what your getting into lifting that much?
Personally I think you'd be more than happy w a 6" lift and 40's.
03-22-2012, 01:02 AM
Gu big or go home. With a 12 inch lift go with 49's for sure. But you wont be happy with a 12 inch lift. Unless you are only going for show go for a 6 inch and 40's. Very impractical for a daily driver. IMO
03-22-2012, 03:13 AM
Dont take this the wrong way...I'd be pissed if I was planning on a project and didn't know what else truely needed to be done to make it work. You have a low post count so I have no idea what your experience or knowledge is on this.
I'd search out on the various Hummer forums for other 12" lift owners and see if you can find one and call'em up directly. Speak w/ someone that has first hand experience as a non-show truck, how it handles and the maintenance required.
Wheels, I would not go over 20" unless you want to pay up the ass for rubber.
Lift that size, I wouldn't even attempt to drive it w/ out putting on ALL the upgraded steering components including solid centerlink. Plus an AGR Performance powersteering pump, stocker isn't even going to think about turning those tires under 10mph. Probably have 3G in parts alone, not including install.
Now your going to have a gutless turd on your hands, that couldn't pull out in traffic if your life depended on it. Here comes 5.13 gears. W 40" tires you will be really close to stock, should actually have a little more gear than stock. Good quality Yukon gears, master install kit w/ timken bearings will run you another grand. Plus $1100-1800 installation.
Now you can turn the wheels and actually drive the truck, your only problem now is it wont stop. I put brembo 6 piston caliper brakes on all 4 corners of my rig. You are going to need those, wilwoods or some other big ass brake kit. $5000-9000 Mind you these brakes are designed for factory stock spindles which you dont have anymore. I had about 5 hours or grinding metal to get my brembos to bolt up and have adequate clearance.
Those are the big ball busters...
03-22-2012, 03:18 AM
Nicely put and laid out...
CNTRY
DTOM
03-22-2012, 03:38 AM
Note to self, don't lift my vehicle
